The Sport Box
    I think the wagon deserves a shot at a frame upgrade, you can work around the different gas tank.
    Cut and paste, a little bit of this
    and a little bit of that.
      now to get that modular piece of shit out of the way for a proper motor, and you're good to go.
        Seconded.
        In other news, my money's on the beige '85 coupe. Of all the boxes in your fleet, that's the one that's most in need of handling improvement. New frame + new suspension is right up its alley. Plus, you can follow what Serge did (interior dimensions, relocating of things like the exhaust, steering shaft, and so on), and skirt the issues with the wagon gas tank.
        '89 Grand Marquis "Ebyt", '85 Grand Marquis "Eva", '94 Caprice "Kira"
        '80 Mark VI "Allie", '88 Town Car "Lana" coming May, '79 LTD-S "Oksana", '94 Grand Marquis coming 2026
          Put a Coyote in there.
            I'll be using everything from the 04', from the frame, engine, trans, all the wiring, everything. However, the interior and exterior will be 100% box. I can't afford any neat engines, I'll use what I have.
            The one thing I refuse to use is a whale dash. It's no longer a box if it has a modern dash. Since I do need to use the 90+ style steering column, I'll have to use a 90-94 GM dash or 90/91 Vic dash. I'd even settle for a 92-94 Vic dash or maybe an aero towncar dash.
            As for the car, It won't be the Tudor, that car is pretty much already sold.
            I've thought about the 91 wagon as it would make the dash part of the swap easier, but then it would no longer be the battle wagon, plus it's a beater.
            I was planning on originally doing this swap on the 87 CP, but I'm really not sure. I'm thinking of dropping the HPP box's everything in it instead, and turning the HPP box into the Sport Box.
            As for the front tires, the original rims had been sold off the car, and it was rocking 98-02 steelies, but I was afraid they'd be too wide for my buddies tow dolly so I just went and grabbed some 03+ steelies at the JY. These shot 17's were the only ones I could find. Oh well, good cheater slicks.
            More tear down,
            Nothing left of the interior:
            Entire body wiring harness removed, all 70lbs worth:
              You could always mod the steering shaft and keep the stock dash.
                Do it different! Do the wagon!!
                  Let's hope the peer pressure sets in..
                  Ain't sporty without a clutch!
                  Originally posted by SVT98t
                    I wonder if those window motors fit the older aeros. If you wanna part out some of that, if it'll fit aero regulators (93 specifically), I'll buy the driver rear off ya.
                      It'd be cool to do the 87 CP but the hot rod in me says do it to the lightest car you have. Are 2 doors the same weight, assuming same options? They have the same frame and length so I'd think so but maybe not. But yeah, lightest car plus 5 or 6spd swap.
                        wagons have a longer wheelbase
                        nice project mang!
                          nice project mang!
                          Which part is longer?
                            wagons have a longer wheelbase!
                            I didn't know this - is it the same wheelbase as the Town Car? The rear wheel arch cutout in the back doors looks the same, so are the wagon rear doors longer?
                            RyPow
                            1987 LTD Crown Victoria LX sedan - The "Sand Box" - 73K, towing package
                            1987 LTD Crown Victoria LX Tutone Tudor - '96 Explorer 5.0 + 5spd swap in the works
                            1985 Lincoln Town Car Cartier - previously owned by "navguy12" from thelincolnforum.net
                            2007 Lincoln Town Car Signature Limited, 102k, daily driver
                            2006 Mercury Grand Marquis LS, 115k, winter beats
                            1977 Lincoln Continental Town Car, 42k
                            2012 F-150 5.0L 4x4, HD payload pkg (towing/hauling)
                            2015 Toyota RAV4 XLE AWD (better half's)
                              I believe the rear floor area is longer. The rear doors are different on a wagon. Might be the same as the Townie wheelbase.
                                Comparing images of the 2 cars the lengths look the same.
