That red wire. Does it have 12v? If so, does it have a fuse?
Buyer's Remorse (AKA "Hideous") - Giraffe's 1990 Grand Marquis LS
Originally posted by Tiggie View PostThat red wire. Does it have 12v? If so, does it have a fuse?—John
1985 Ford F-150 XLT Lariat
Is your knock present hot/cold/all the time?1990 Country Squire - weekend cruiser, next project
Originally posted by Grand Marquis GT View PostI used to dump a can of "restore" in with every oil change. It seemed to quell the lopo knock.
Originally posted by Tiggie View PostIs your knock present hot/cold/all the time?
I bought a new Motorcraft battery for it yesterday; it cranks on its own now. I just need the solenoid and I should be able to get rid of that stupid switch as well. I'd like to start daily driving it next week. I also noticed that is has a pronounced oil leak coming from somewhere on the driver's side that's leaking onto the cat making it smoke constantly. It's also dripping on the ground at a rate of about two drops per minute. There's so much dirt/oil everywhere that I really can't tell where it's coming from.—John
Gonna grab these. I can get 100 for the price of two cards of three. Always good to have spares.
—John
I usually suggest a stereo upgrade instead of magic potion in the engine. Fix the knock properly when it becomes a real problem with an actual engine.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostI usually suggest a stereo upgrade instead of magic potion in the engine. Fix the knock properly when it becomes a real problem with an actual engine.—John
Nice find on the regulator bushings.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
For the source of the oil leak, my first guess would be valve cover gaskets. Make sure the valve cover bolts are not loose, I came across that recently.
If that's not it, my second guess would be the lower intake gasket. I would think this would be less likely than valve covers gaskets.
If the source is still not identified, check the PCV. The grommet along wit the valve will pop out of the lower intake and oil can escape in the fumes coming from there. If there is significant blow-by, enough oily fumes can escape and the oil accumulate to the point where it drips. Usually the tell-tale sign of that is an oily wiper cowl in that area. I would think this would be highly unlikely to be your source, but if nothing else is found this is the last thing I would check.
Another oil leak I have had in the past is the original oil pressure sensor/switch. That's toward the font by the oil filter, not near the area you describe. That should leak straight down, so not likely your culprit.Vic
What Vic said. If it's that nasty i would take the car to town and pressure wash the motor and then buy permaseal rubber valve cover gaskets and a new lower Intake gasket set. Put a new pcv, screen, distributor o ring, and oil sending unit. Short of oil pan gasket that should fix a lot of oil leaks.-Nick M.
Columbia, SC
