Originally posted by VicCrownVic
View Post
And another incident of "I'm an idiot" today. After the cooling fan fiasco last summer I flushed the cooling system. (The '02ish fan is doing great by the way.) When I refilled it I assumed the remaining water in the block from flushing it would be negligible. Well, turns out that assumption wasn't so true (assuming I've diagnosed my situation properly). It was so cold this morning but my temp gauge pegged high and the digidash started beeping at me. Thinking it was a fluke or bad sensor I pulled over on a dirt road and let it idle a minute. The gauge stayed pegged. So I shut it off a minute (also, it was still completely dark outside). Checked under hood and nothing was off/wrong yet. Started the car again and the gauge was normal temperature. Decided to turn around and work from home anyway just in case. I was only 8.5 miles (13.679km) from home. I made it 0.5mi (0.8km) and it started to boil over. Pulled off onto a other dirt road and shut it off a bit longer (the sun was getting close to rising by now). Looked under the hood again to make sure I didn't have blown hoses or anything major, and I found that I didn't have anything more than typical boil over. When I started the car again the gauge was normal again and stayed that way the 8 miles back home.
So, based on the steady -12°F (-24.44°C) on my outside air temp right before this all happened, I've figured that my water to antifreeze ratio was closer to 60/40 which has a freezing point of -10°F (-23.33° C) so maybe between 55/45 and 60/40. I figure this less than ideal ratio allowed the coolant in the radiator to freeze at -12°F. The boil over perhaps thawed the radiator enough to reestablish flow.
After I was done working for the day, I filled with concentrated antifreeze to make the ratio better, then I let it get up to temp to make sure there were no leaks and everything looked good. I then threw the garbage cans in the trunk to make the 600ft (about 183m) round trip down and back up my driveway to put the trash to the road. Then I found an excuse to run to town (2 mile (3.22km) round trip) just to get some drive time in.
As long as it really was freezing coolant in the radiator, I think I should be good to go now. The much warmer temps forcasetd for tomorrow morning (16°F/ -8.889°C) so that should help too.
