I like the thought of having one but what do i need to send someone to do it?
Can i use the ones that have a digital tach to? and temepture readings?
i took one out of an '87 cougar and mocked it up to fit in the place of the stock speedo. right now i'm needing to finish the tinted plexi-glass to make it look perfect and finish the sensor swaps. if your thinging of this one you have to change the coolant, oil presure,and fuel level senders. as well as run a line from the coil to the tach so it can read. and if you want the fuel economy part to work you have to add a wire from the brain(pin#35) to the cluster for fuel flow.it is not a swap for the faint of heart,sodering challanged,or some one who does not have a back-up car. that's why mine took so long my wifes car broke down so the vic became the only mode of trasport we had
for those of you who want to see it done i'm trying to get my brother to come over with his digital camera to get good pics. my cheapy just looked like the dash had a blue neaon bar where the guages should have been
