ok so my rear windows dont work right they will roll down fine but going up they seem like they are skipping i took my door panels apart to find that i have the metal gear window motors and nothing is stripped is the motor bad can i replace just the motor or do i have to get the whole assembly motor and gear together
help with power windows
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
I'm guessing the bushings in the transmissions are going bad. Here's the sticky thread about it:
http://www.grandmarq.net/vb/showthread.php?t=11047
yes sometimes the bushings are so far gone you cant tell they were even there. Sounds like thats the problem.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
