Recently purchased a low mileage 06 GM with cluster issues. Previous owner said one day the cluster stopped working. Blinkers and air bag lights work on cluster, however everything else doesnt. I’ve read some sodering can repair these clusters. I have mine apart and am wondering which points on the motherboard need repair? Any tutorial videos online are all Crown Vic. Otherwise I’ll have to send it out for repair. Appreciate the help.
06 Grand Marquis Speedo, RPM, Temp & Fuel Gauge Repair?
Typical spots are the through hole stuff for the connector and the screen. Look at the solder joints and if you see a line (crack in the solder) or the thing wiggles in place, reflow that solder joint. Once you've done all the broken solder joints, it should work.
- Likes 1
Originally posted by sly View PostTypical spots are the through hole stuff for the connector and the screen. Look at the solder joints and if you see a line (crack in the solder) or the thing wiggles in place, reflow that solder joint. Once you've done all the broken solder joints, it should work.
The pins on the screen should go through the board. I'd be looking at everything from the back side of the board and checking solder joints on through-hole stuff. Anything surface mounted on the top should be fine. I zoomed in on the pic and see plenty of pins from the screen going through the board and look like they don't have enough solder on them. I would definitely check from the back side of the board.
This thread may have info you are looking for: https://www.grandmarq.net/vb/forum/t...dometer-repairVic
