Help with lumbar suport
    ok the blasted lumbar suport on my 94 GM is all the way inflated. Is there a way to deflate this as the switch seems to do nothing
    theres an easy way if you never want to use it again... you could try removing the switch and bypassing it, if its bad it might work.
      You could see if you can find another switch module in the boneyard. Does the switch work the inflate side? Can you hear the motor running when you press the inflate side of it? You should be hearing some sort of click when you press the deflate side; if you're hearing nothing either way, it's almost definitely the switch and you should see if you can find another one.
        no nothing from the switch for the lumbar ,, power works fine. tried pulling both the hoses ff the lumbar switch and did nothing.
        have to get a switch in the next few weeks, cause no I do not want to stick a hole in the leather seats!!!
