I have been thinking about taking the small bulb out of the second segment of the turn signal reflector assembly, and carefully filing the same pattern as the other bulb socket, (The turn/parking light bulb socket) using the original hole where the small bulb was, and add another socket and bulb, to have two bulbs that work as parking lights and turn signals... should be pretty easy to do... Who knows, I may add another socket to the corner lense too, to make them flash, too.... instead of just an indicator light, like it is now.... I just hate the fact that the outside segment doesn't flash with the turn signals, and is alot dimmer than the other parking light when it is on.... Pictures before and after when I get time to do it....
Tom!
Tom!
