I am tired of telling people there has to be!
    Ok, will someone tell me they know what I am talking about!
    On my '86 Tudor MGM 5.0 there are no upper ball joint(s)........just a thick piece of rubber!
    Only the bottom of the suspension has ball joints.
    So why are so many I speak to insistent that my car HAS to have upper ball joints!
    My '79 Ford LTD was the same .....no upper balls.
    There is a rubber boot over the joint. If that's what you're talking about. Your car has ball joints. Uppers and lowers.
      You have upper ball joints and so did your '79.
        The upper ball joint looks a little different from the angle you are most likely looking at it, and the top of the upper (if you can see it) looks different than the bottom of the lower. Assuming they have been replaced at least once, you should find a grease fitting if you dig through the pile of dirt/grease on top that may be hiding it.
          Are you perhaps talking about the thick rubber weather shields? They cover the upper control arms from certain angles.
            say what?
              You know, I have been looking at the car for yrs, same as the '79 LTD.........and I only see the upper arm attached to a very thick slab of rubber, Christ, I have got to get this POS on the lift and see for myself!
              This is insane!...........180 degrees different than my Studebaker front end with king pins and 22 zerks!!
                pics would help.......79's were odd, tubular upper arms, they went to the stamped arms sometime in 1980
                  I've seen those tubular arms on 1980 Towncars. They did have upper ball joints, but I think it was a different and specific one that can't be gotten. The fix for those is changing the arms to later ones. But yeah, its got ball joints in there someplace. Baby LTD or Marquis does not, but thats a different animal entirely.
                    Take some pictures for us. I think you are seeing the weather (splash) shields.
                      yeah there is absolutely a ball-joint on every panther chassis car. They're upper and lower A-arm style cars, and the only way any company has designed those for decades is with a balljoint. Don't let any coverings fool you.
                        There's is no way a hunk of rubber can with stand the forces needed to keep the front suspension together. The springs alone has enough force to kill a man. Not to mention forces of braking, cornering, or even going over railroad tracks. Rubber would not work. Like the other guys are saying the proof is in the pics…lets see some pics of what you’re talking about.
                        George Burns
                          I hate to admit this, but I do not think the upper bj's were ever lubed:-(..............I purchased the car from the original owner about 15 years ago, and as I am always with the car while on the lift, I always remember the tech saying no upper ball to lube, and I feel stupid because I only saw what appeared to be a huge solid piece of rubber at the upper portion of the spindle!
                          So, assume the car has never had the upper bj's lubed, what damage have I done, and more to the point, how do I know if I have done damage? Is there a plug that must be removed to put in a standard Zerk fitting??
                          Guys, don't beat me up too severely:-(
                            Not sure which years that Ford started the practice, but the suspension joints stopped using grease zerks and were "sealed for life". I think this was probably on the 90+ models, though. If the upper ball joints were replaced, its possible that they did not have zerks either. I try to stick with Moog replacements as they usually have a zerk.
                            Nick
                            Past: 1967 Continental convertible, 1987 TC Cartier, 1996 TC DAE & Signature, 2002 LS V8, 2006 Zephyr, 2010 MKZ AWD, and many more.....
                            Current: 2010 F-150 Platinum Supercrew 4x4
                            Wanted: 1967 or 1969 Contnential sedan
                            Only in my dreams: A Continental Mark II
                              Don't worry. There is no such thing as a dumb question if you don't know. We all started out at the beginning and choose to learn.
                              I catch lube people all the time that say "There are no fittings to lube." That means they don't know and don't want to look. Lube people always miss the two zerks at the ends of the upper A arms on my police suspension cars.
                              If there is a plug, it has to be removed to thread the zerk fitting on. There are different sizes for different applications.
                              As far as damage done. The worse thing would be having to change the upper ball joints. That should be done if there is excessive movement in the joint. A good alignment man could check it out for you.
