I will get on the fuel flow tomorrow and will post my results
tripminder
This is a sticky topic.
cant use it - who wants it? $30 for the one with harness, $25 for the one with just pigtails
factory shop manual scan courtesy of Rexx
Anyone have any luck adding pin #34 yet?
I clipped an ECM harness off a junker that has the #34 wire w/connector if anyone wants it.
Without it all of the fuel functions of the tripminder wont work.
On a side note I found out why I had to bore out the VSS on mine. Cars with cruise control have a different speedometer cable than those without.
So far after a month and a half it's still working flawlessly, and I'm amazed at how acurate the damn thing is!
-Paul
naw i havent bother messin wit it in a while.. But if you use that harness dont you have to splice it on wire by wire?
The harness I clipped has thePIN #34 wire w/factory connector.
