I replaced the multifuction switch a few months back that had went bad and my head lights nor my high beams would come on with out me holding the multi switch aka pullin it forward to me like im turning on and off the high beams.. Tonight i cut my car off and when i turned it back on my head lights would not come on.. The only way they are workin is when i turn on the high beams. They come on fine and i can drive with all for lights on. But the low beam will not come one by it self. So what do you guys think multi switch could have been a bad one from the yard waitin the yard waitin the blow? Or maybe a fuse link at the starter solenoid on the fenderwall? If so what would be a sign that its blown with out having to break out my multimeter.. Could it be teh headlight switch i replaced that also.. All the orange parking lights and cornering lights work with no problem...I know its has to be one of these items just tryin to narrow it down.. Any help or suggestions would be helpful... Again like always guys thanks for the help in advance...Dont know what i would do with out cha
