Originally posted by 1987cp
View Post
Originally posted by Mercracer View PostI am on number 6 or 7 used Explorer motors in different applications without having to do anything but swap valve springs, timing covers, oil pans, etc.. 3 of them have had 150 to 175 shots of nitrous run through them and I know of 1 person using one with a turbo and another person with a Paxton blower. Low boost and a good tune...2012 Mazda5 Touring | Finally working on the LTD again!
I never did figure out what had been done to the engine I bought ... the cylinder where the spark plug threads were unrecognizable and the sparker held in place with JB Weld looked like someone had beaten on the piston and the underside of the head with a hammer. IIRC it was a different cylinder that had the nasty fingernail mark on it, and then there was the weirdly-worn rod bearings that all were basically unworn in two places and worn mostly through the copper in two places.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1984colonypark View Post460=1 302 t5=0 i need more votesOriginally posted by 1984colonypark View Posti could trick out the 460 for less then u could get i ragged out expo engine at a junk yard at least around here
No problem with that as a 460 swap done right will really motorvate your wagon, so let's focus on this fact that you are doing the 460 transplant.
Originally posted by 1984colonypark View Posti think its funny how everyone jus wants to tell me to find an explorer enigne like i jus have one laying around right? i listed what i have and if your trying to cinvince me its cheaper to go and buy a explorer engine and start over versus the 460 your smoking crack. having a new drive shaft built and exhaust and welding in a set of engine mount points is NOT more expensive then buying a whole other engine. like i said i have the 460 fresh rebuild and its not sportin the smog pistons, heads or cam. and i already have a rebuilt c6 and the fox chassis pan and pickup tube kit.
Let's keep this thread on track with discussing your 460 engine and how you will be putting it in your wagon.Last edited by Mercracer; 12-22-2010, 01:14 PM.
as of now mustang bob helped with the mounts by giving advice on early 70's lincoln mounts. i've acquired those yesterday. the heads are 1972 models that have been port matched to my performer intake the pistons are flat tops by keith black kb137-030, as soon as i saw the dished stock pistons they had to go. i still need to check the com bustion chambers cc's. should come up to around 10 to 1 on compression when done. went .030 on the cylinders, went with edelbrock 2167 cam and lifters with 272 int./282 exh. duration. the mounts were probably the easiest part so far, the drive shaft came to around 200, a high school friend of my father owns the driveshaft shop so i got a deal there. the biggest ordeal thus far has been the trans tunnel room in my wagon. once i torched the trans tunnel out and customized the hell out of the trans cross member mount points to get in all bolted in. it barely fit under the hood after i had to "massage" the hood bracing. like i said jus drilled some holes and the mounts litterally fell into place with bolts. the exhaust so far will be the biggest prob so far i've seen. any more help with how to make it fit there bob lol. one person told me to jus cut the trans tunnel out of the lincoln parts car i got the mounts out of but its very large in comparison to the wags
I would be suprised if you were able to get to 10:1 with those heads. How big are the reliefs in the piston tops? The chambers on D2VE heads are huge (92+ccs). Those are the only 429/460 head with an "open" combustion chamber. Nobody makes a piston to match them properly. They are prone to detonation. A Performer intake is like breathing through a straw...Last edited by Mercracer; 12-30-2010, 06:37 PM.
