Hi, im building an 85 for someone, and wanted to run it by you guys...First off, ill say ive been in the ford world forever, and my wrenching skills are hard
This vic is getting a 5.0 ho roller block with the original aod. it will recieve an sefi conversion.
First off, I noticed the cfi return and pressure are on opposite sides. Which side is which. Any of you done this conversion? Did ubuse mustang fuel rails and the front metal lines? What did you do to extend the body lines.
I have several harnesses...I dont care about mass air, ...I have an 87, 89, and 90 mustang harness. Which harness is best to use? Research tells me maybe the 86-89 mustang harness? If anyone has done this swap and has a pointer on the electrical that needs to be spliced , im all ears ..I have a pretty good idea ..but not 100% yet
Sent from my SPH-L710 using Tapatalk
