I just ordered 2 245/60/R15 Yokohama Avid S/Ts from Tire Rack. I will have those mounted and see how they fit. From there I will decide on the size for the rear wheels.
Tire Size?
235/70/15 front and 255/70/15 rear (w/ wagon springs) on stock turbines, no probs so far.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Mine is running 235/70/15's all around. They are Goodyear Aquatread III's which i think were replaced by the Goodyear Assurance. I have no complaints except i think the larger size messes with the speedometer a bit.
1986 Grand Marquis LS - coupe [/url] http://photos.yahoo.com/leo76830sigpic
1986 Grand Marquis LS 2 Door
Im running tiny ass 235/75's right now on teh back. They should be fun.1989 Grand Marquis LS
All you guys running the 235/75R15 tires, I got a question for ya - are you absolutely sure you know what you're doing? No offense, but what you have is 2" larger in diameter than the stock 215/70R15, which speeds your vehicle up by almost 8%. The maximum allowed (due to brake safety concerns) is 5% only, so by running so big wheels you're just pushing your luck... real hard at that. With the stock tires and the stock 2.73 open differential my car gets to 120mph without a problem, and the engine isn't anywhere near redlining, how much faster do you want to go? If you want high speed go for different gears, not for brake-melting truck-sized wheels. 235/65R15 will be perfect but that's pretty hard to find, so go for the 235/70R15 - that's a little taller but still within limits.
I was running 31x10.50's on the back. I have a 225/75 fronts and 235/75 rears. I do know what im doing. My car stops fine. My speedo is off but I dont care. And what are these rules you speak of? Ive never heard of them. And GL you cant run a 235/75 front without rubbing. My 225/75's run the back of the inner fender where the frame is. If you dont mind the rubbing a 31 will clear on the front.1989 Grand Marquis LS
Southern_Pride, calm down man - just wanted to make sure you guys are aware of the potential dangers, after all we're all here to help each other, right? The rule about the 5% I've heard at some tire shops (as Blaze86Vic noticed), got it confirmed at work later on... guess it's just a piece of mind, rather than an aboslute must, but it was worth sharing it.
Sorry about the feeling of being angry. I was a bit jumpy this morning. Ive probably never heard of the rules because I mount my own tires. I dont balance em.1989 Grand Marquis LS
Only about 110 on the interstate. they dont shake anywhere. Got over 20k on these.1989 Grand Marquis LS
Originally posted by Blaze86VicA 2" larger tire is nothing compared to going to 20" weels.
