Man, you better have that ride of yours at SF. I've been looking forward to seeing your CV.
I hope you're not looking to see a show quality paint job... I've still got the dang sticky crap from the strips across the doors.
Well, it won' take more than 2 hours TOPS, to install it. I just need the converter here in time for me to install it. Now I have to catch up with the cleaning!
I need to re-install the 3rd LED in my line lock indicator.
Then put my right side dash back together.
I've still got 75% of the car to wax!!
Wheels need to be cleaned, just for good measure.
Tires need to be shined.
I need to do a quick clean inside.
A little wiping on the engine area, I'm not going to spend all day there. (Though I prolly should)
Alright so no more hangin out at the friends house....going home now to work on the Vic.
I didn't rebuild it this time. I ordered a new one, hence the issues of getting it in time.
TRANNY SPECS:
Wide ratio 4R70W gear set,
4 clutch second gear,
Mechaical diode for second gear,
High energy performance frictions,
A Servo. and Redlined Wide band for OD,
Combination of Bauman/Suoerior SHIFT KITs,
OD-2-1 shift pattern as well.
silly people and your wax jobs. Hell, my car isn't even ABLE to be waxed. If I want it shined up, I'll have to wet sand the hood and trunk because the PO's spraypaint job on them. If I had the time, I'd do it, but as usual I have 49021389 things to do in the meantime.
Well, that's what I did to the virtical portion of the trunk lid. Got overspray from my rust clean up on the outside. And I don't have a clear coat paint job.
