I bet it's been asked before, but I don't remember seeing it recently. Anywho, what's the difference between EFI, CFI, and Carb? I know what the difference between EFI and Carb is, but not EFI and CFI or CFI and Carb. So basically what does Cfi stand for and how does it work and relate to EFI and Carb?
This is a stupid question
CFI is Central Fuel Injection...
it's much like a 2bbl carb, only instead of barrels, it has injectors.
whereas EFI has the injectors in the lower intake manifold, spraying directly into each cylinder.
I consider CFI a hybrid between EFI and Carb. "Carbureted Fuel Injection" if you will...Last edited by Mr. Land Yacht; 07-28-2006, 03:20 PM.sigpic
Electronic Fuel Injection (EFI) is a general term that covers many types of fuel injection, like Central Fuel Injection (CFI), MultiPort Fuel Injection (MPFI)and SEquential Fuel Injection (SEFI)
a carb is just a carb... no relation. The VV carb was an attept at an electronicly controlled carb...Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Some people refer to sefi and mpfi as the same thing, but are they different? Were the 86-91 5.0 engines referred to as MPFI engines and the newer panthers 92+ use SEFI on the 4.6?Current rides - 1991 Ford Thunderbird 3.8 v6 (gas saver/DD) - New Heads/Headgaskets with ARP studs, Air Silencer Delete, 70mm MAF, Plasti-dipped Matte Black with a Silver Metalflake Overlay, Muffler Delete, some LED's, 30.233 MPG for high MPG average!
Associated Panthers:
I'll ask the stupid questions around here, son. JK, love how no one here judges when someone like me posts dumb questions, or the same question multiple times (short term memory prob.?).
1991 Crown Victoria LTD, Puff the Magik Dragon
i think MPFI is different from SEFI in the way it fires the injectors... I dunno when it changedPete ::::>>> resident LED addict and CFI defector LED bulb replacements
MPFI just means multiport fuel injection. Its actually what GM called thier system. SEFI means sequential EFI, which means the injectors have a firing order. Each injector fires when that cylinder is on the intake stroke. There is also batch-fire injection which also uses 8 injectors. Ford trucks use this system. The injectors are wired in banks of 4, and they alternately fire.86 Lincoln Town Car (Galactica).
