Nitrous CFI in the Works!
    Read this post.
    http://www.grandmarq.net/vb/showthread.php?t=22245
    You may want to consider doing the spacer mod...
    2000 Grand Marquis LS
    Mercury Owners Group member
      OK, just so long as you've got some ideas about how to give it the fuel it wants. That was mostly my concern, along with the crappy pistons and usually shot to hell timing chains on the pre-roller engines. If it works, it would be cool but sometimes people post crazy shit and have no idea how to pull it off. I wasn't sure if this was one of those posts or not.
        Have not had time to work on this project this week due to weather and my work schedule. But hope to continue this weekend. Have purchased new motorcraft copper plugs(2 heat ranges colder than stock) to replace the platinums i have in there now. Just need to connect the wires, and install the switches, and start testing. More to come later.
        NA-15.78@91.21, 80hp shot-14.48@96.21
          I basically know very little about nitrous so i could be way off here...but wouldn't you want plugs that could handle higher temperatures then stock if your using nitrous? Just curious
          -Phil
            FWIW, I had a cfi motor I converted to carb in an old mustang I had, and with a 100hp on it, it ate the plastic timing gears to peices, then the peices of the timing gear clogged the oil pump and killed the motor. So be very very cautious or just replace the timing set haha
            '90 LX 5.0 mustang
            Big plans
              You use plugs of a colder heat range because they dissapate heat quicker. If not the stock plugs may stay or get hot leading to detonation. You use copper plugs because nitrous will react with platinum altering their composition.
                1980c10, Im pretty sure a 100 shot on mine, would do the same or scatter pistons and connecting rods everywhere! LOL
                  Just helping out a fellow rodder. Just hate to see your engine get killed over a $20 timing set like mine did. But I was young and didnt know they were plastic until it was to late, now I know better haha.
                  '90 LX 5.0 mustang
                  Big plans
                    Killed? $20 timing set? Plastic?
                    Replacement timing sets are always all-metal .....
                      Yes, but the stock ones aren't.
                        Yes that's what I was saying, it will only cost around $20 for an all metal replacement.
                        A small bit of insurance over the stock plastic unit.
                        '90 LX 5.0 mustang
                        Big plans
                          Oh, I see, someone must have been too cheap to add a $20ish replacement timing when they rebuilt an engine, and got burned when the nylon cam sprocket disintigrated.
                            he didnt say anything about the engine being re-built...
                              indeed, All I did was yank it out of the vic, did a carb conversion and shoved it in the stang. Then proceeded with the n2o haha
                              I bought the rolling chassis for $400, got the vic for $100 for the donor motor, had a mustang AOD laying around and had everything for the carb conversion I needed, then bought the n2o sniper kit for like $350. I had a fun weekend car for $850 sort of like a granade project haha I knew it would happen and didnt care and wasnt gonna spend money on a lopo.
                              '90 LX 5.0 mustang
                              Big plans
                                Let's keep this on topic folks, getting way off target....
