Greetings,
I have an issue where the engine is running normally when cold, but when it gets hot it will ping, which is quite noticable under load. I tried premium gas and this seemed to help a little. I was wondering if it could be caused by a bad spark plug. I have had the car for 2 years or so and I don't know when they were last changed. Would this be a good place to start? I will also check the codes when I have time. I did try adjusting the timing but I had difficulty seeing the marks on the harmonic balancer so I just kind of left it where it seemed happy. (The pinging started before I did this.)
Thanks guys.
PS - I had a profile here a year or so ago but I lost it so I'm back with this one. I'm the weirdo that flushed his engine out with transmission fluid if you remember that!
Thanks guys.
