i spilled a little coolant, i'd say less than 1/4 cup, into the oil pan as I was doing the timing cover. should I drain out the oil (its new) or is a little bit ok?
little bit of coolant in the oil ok?
just crack both plugs untill the coolant runs out. It will be at the bottom.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
yeah get it out of there. If the motor hasn't been run you should be able to drain just the coolant out of the front sump. It'll be at the bottom like Pete said. Once it turns into a milkshake you might as well forget it. coolant + bearings = bottom end rebuld86 Lincoln Town Car (Galactica).
Originally posted by Blaze86VicJust to be safe, it's worth it to do a complete oil change.
Bearings big bucks2000 Grand Marquis LS
Mercury Owners Group member
Ya should do an oil change after cracking open the motor anyways. Dirt and moisture can get in
hahaha I'm definately changing the entire oil, in the front it became a milkshake and its kinda green.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Re: little bit of coolant in the oil ok?
Originally posted by 89LincolnTWNcaror is a little bit ok?
"I promise to only put it in a little bit"
Seriously man, always change the oil after any surgery on your motor. I have seen loose gasket material plug up a oil pickup.
Originally posted by Mercracer
"I promise to only put it in a little bit"http://secondhandracing.com/Home.aspx
Originally posted by MercracerSeriously mang, always change the oil after any surgery on your motor. I have seen loose gasket material plug up a oil pickup.86 Lincoln Town Car (Galactica).
