connecting single strands of wire?
    Those LED strips I bought on ebay arrived today....the -/+ wires are only one strand each, though. I feel like I'm going to pull them off of there when I go to splice them in - I just don't know how to splice them in? The smallest butt splice connectors I have are 18 gauge and I don't see them holding these in there.
    http://www.advrider.com/forums/showthread.php?t=281500
    Good old fashioned soldering FTW.
      Buy yourself a soldering iron if you haven't got one already, it's the best way to make any kind of electrical connection because the resistance is less with a good solid connection. You can use electrical tape over the solder join or if you want to get all fancy, buy some thin heat shrink and use either a hair dryer or a lighter to shrink around connection.
      2002 Mercury Grand Marquis GS 4.6L V8, 1988 Mercury Grand Marquis GS 5.0L V8, 1979 Lincoln Mark V 6.6L V8, 1977 Lincoln Continental 7.5L V8, 1999 Chevrolet Suburban LT 5.7L V8
        I don't have any soldering gear, or any money to get it, really
          Irons can be had for less than $10 and solder in small lengths is a few bucks. Unless of course you really don't have 2 dimes to rub together.
            No, I really don't for the next few days. Didn't think I would be driving as much as I was this week and burned through a shitload of gas.
            EDIT: I guess I'll need to learn how to solder then, huh?
              It's not difficult at all. The key to a good solder joint is heat. You need to get the wires nice and hot so the solder flows and cools properly. Not enought heat and you could end up with a cold solder joint which will either break the moment you move the wire or will fail over time. I usually 'tin' each wire with solder first, then twist the wires together and heat the wires while adding a little more solder. Once it has cooled it should remain trouble free for many years.
                Tip #1 for the begginer: Melt a bit (not a blob) of solder onto the tip BEFORE trying to heat the wires. The melted solder will form around your wire and heat it up quicker so you can tin and solder it easier.
                Practice with scrap wire and circuit boards to get a feel for it. Remove components (two or three legged ones) without breaking them. You'll destroy a few at first, but then it'll become second nature.
                Alex.
                  Is there a way to connect these wires to other, bigger ones without soldering? I have free time and was hoping to get some of this done
                    Single strand? not really. You're never going to get that to crimp into anything.
                      You don't need a super great connection for LED things... i usually just fold the wire back over the insulation and crimp the insulation and all in that situation. I've seen a lot of OE crimps done that way.
                        Noted.
                        thanks fellas.
