Can I swap my idle control off the 1990 TC TB or should I try to use the one that came with the Explorer engine? The electrical connections are different and it would be nice to use the old one.
Pics:
I had one big reply with all of this but lost it. DAMMIT!!! I was pissed. It took 20 minutes or more to express my questions so sorry about the different replies.
One more question:
I had major problems installing the injectors in the intake. I decided to just install them into the fuel rail then bolt the fuel rail down. The injectors don''t just slip in the intake like they did the fuel rail.
Is this the best way? They don't go all the way into the intake but get a decent seal as far as I can tell.
Please help.
Suggestions?
Procedures in which you install injectors?
Belt for A/C but no smog is 560k6, and other belts that interchange with that number.
It's been awhile, but I'm pretty sure that the injectors will go on easier if you put them into the intake first, and then put the rail on top. Lube all the o-rings up with gasoline so that they don't stick and tear when you put them in.
electrically I believe the later ACT is the same. You can just adapt the plug.
use the 1990 IAC, or the Explorer one should work if you swap the plug
The TPS thing is questionable. Some don't seem to fit right, others do. Mine worked ok, but others have had trouble. You can either use the early TPS, or you can change the plug to use the Explorer piece.
I've always stuck the injectors in the rail first, then put the whole assembly in the intake. Clean the holes in the intake out so they aren't all rough and corroded, and smear some sort of lube on there so the O rings don't tear. Vaseline, wheel bearing grease, motor oil, whatever is handy should do the job just fine.
I cleaned out the fuel rail and the intake manifold seats with q-tips and di-electric grease... a little bit on the o-rings and they just slipped right in.
Thanks Gadget.
So basically all of the sensors, ACT, IAC, TPS can all be used as long as I swap the electrical connections. I may try to use the old TPS though just to see.
I think I will try grease or something slicker than motor oil on the injectors.
That is what I wanted. Just to hear from someone who has done this before. I am a virgin with these type of injectors.
Definitely do not apply vacuum to the nipple on the filler neck.
Thanks. I got the filler neck thing figured out. Just a good clean air supply, filtered.
Thanks HPP
The valve cover nipple is actually letting fumes get sucked back into the engine via the throttle body.
No. That's what the pcv system is. That pipe goes from the throttle body to the valve cover gives it air that has been metered by the engine's fuel control systems, Mass air especially. It does NOT and IS NOT SUPPOSED TO suck the vapors through the throttle body.
I mistyped about the vacuum to that. The pipe on the throttle body is for a breather, not vacuum.
or if you have a slapped out motor, its to allow crankcase pressure to force oil into the throttle body Its original design is an air inlet, but when old age and abuse set in, it serves other purposes.
I found the problem with the injectors. The o-rings were installed too far up on the injectors.
I have had help but I will take the blame. I should have known and should have inspected them.
Oh well they are in no problem
Now valve covers some wires and the upper intake. Some oil, antifreeze and a few other things left.
You guys will really like the way I deleted the egr plate behind the TB. That will be a surprise. I will get pics, stay tuned.
Thanks again for all of your help. More pics coming soon. I promise.
yep! my PCV filter and screen were original with about 150k kilometers on them, dirty as shit. Started sending drops up into the throttle body.
