What I have so far:
Comp Cams camshaft-
INT/EXH 254/262 (advance duration)
Duration @ .050 210/218
Valve lift .477/.493
Love separation 111.0
Things I need:
Valve springs, retainers and locks (shims?)
Lifters (summit)
Timing chain and gear set (summit)
HEI distributor
Oil pump?
Anything I'm missing to do a cam swap? I've already got all the gaskets and such. I've got a few suggestions on valve spring, locks and retainers, anyone else have any suggestions? What are is the diameter of stock valve stems?
Comp Cams camshaft-
Things I need:
Lifters (summit)
HEI distributor
Oil pump?
