Okay Dokie Pt II
    Humm. Allrighty. I dumped one gallon in allready ill dump one more. dont want to dump to much though. As well. i might be having to drop the tank.
      Well give yall an update. Went got new igntion controle module, i said wth only 20 bucks anyways. Well, that wasnt it. I infact dont have any spark. Checked the coil by swaping it out. Didnt work. Put gas in got about a 1 1/2 quart worth now in the tank. Plenty. Still no good. Checked my fuel lines nothing wrong there. re checked plugs plug wires about a dozen times. nothing bad there either...
      I dont get it... Any one have an idea? cause i done shot my wad.
      One more note.
      Usualy when i put my key on i hear two noises. One is a low drawn noise kind of a pur. thats the pump. The other is a high pitch noise kinda like the old pump. coming from under the hood. wtf it is i have no idea. anyways, that noise isnt making any more. It made it a secound ago. However it stoped agine. I tried wiggle test on a few wires. No aval.
        Do you have spark or no? Is the fuel pump running? Do you have 12v at the + side of the coil?
          Checked for spark didnt have none :/ fuel pump is turning on. Havent checked the voltage yet at the coil.
            Went out and checked my volt at the coil. Now my reader is a bit off it's oine of them yellow things, and i have knowen that it's off for some time now. Anyways. Aye i have volts to the coil, it says i have 32. on the other side says i have 16. Im no guru on eletrical aqipment I think you guys know that, so i have no idea how to set the meter to be correct for checking volts on stuff.
            Anyways. just thought ide share hehe
              Check your connections between the distributor and the ignition box. If they're loose or bad, no spark. Also make sure the box is getting power like it should
                kk, Can i ask the best way to tell if the box is getting power? Ok just went and checked all those connections one at the plug on the box wasnt down all the way. Think it was the black one. Mashed it on down, but i done wore my batterie back down.
                If i get my car running agine im going to half to ask you mangs how to make these connections more perminent. Thinking of sodering the lil turds on hehe. but i dunno. Anyways. Guess we will find out in about eh a hour.
                  Probe the connections with the volt meter. If you have a paperclip, stick it in the back side of the connector and read from that
                    It worked, Got her cranked and moved. Im guessing that the old Igntion controle module may have been bad and i just didnt put the wire on the new one good enuff?
                    Ugha.
                    Thanks Gadget mang
                    Unfortunetley i do have a new sound... A Clicking sound, stays on and is rather fast. Sounds like it's coming from around the carb... or vc's ack.. So hot out there.
                    Thanks Agine
                      One more question
                      Hey mang's was woundering if anyone would be able to tell me why sometimes after i turn my key off the engine will stay on and sound like it goes one more cycle? It's not really a problem but it is a wee bit irratating.
                      In other news i think my Umm OD is on the way out. It's been acting like it dosent want to go whille in OD. kinda jerkey.
                        idle set too high will do that. It should be around 700-800 rpm. Its called dieseling, basically the plugs are hot enough that they keep igniting the fuel even with no spark.
                          Thanks mang. I was just thinking that idel might be to high. The idel screws i made it so my vacume was up to snuff. Ima half to fig out which one of the screws by the throtole/tv cabel is a over all idel.I cant member off the top of my head :s. O well i got a video .
                          Also added a bit of tranny fluid almost half a qt as she was a bit low not much however. Didnt help much. with the OD.
                            Also, make sure that you have the right heat range of plugs.
                              + rep to gadget He got it correct :P. Thanks mang.
                              Also i think i knopw what is causing my water system to leak now. You know the pipe thingy that comes out of the intake for the urm, heater hose? I noticed it had some water spots around it decided wth ill get my wrench see if it's loose. And indeed it is a bit loose. So in the AM im gonna take my erm, dizy adaptor loose and turn it around as far as i can and as tight as i can. Question. Are them things easy to ring off. As i dont want to do that and if memorie serves me correctley thats the reasson why its a bit loose.
                                Eh, well i went and tightened up that fitting coming out of the intake for the heater hose.
                                That wasnt the problem i dont recon.
                                When it cools off probley after work tomarow ill check them hose clamps out for the wp bi pass hose. I cant think of anything else that would make it leak and land on the umm. timing cover.
                                Unless the t stat gasket didnt seal correctley.
                                Humm...
                                So if it isnt that bypass hose ill check that out.
                                Just thought ide let you mangs know.
