my check engine light came on once in 1999.......the egr position sensor went south.....that has been the only time since
Scott, you have a CE light in your Townie? Mine doesn't have one, at least none that I've ever seen.
That low oil level light is nice. It clued me in to a leak problem that developed suddenly. I checked the oil when gassing up, it was 1/2 quart low and I ignored it as I was going to change the oil the next day. Next morning, the light pops on and i was 1 1/2 quarts low. Filled up, got to work, it came on again. Turns out the pipe I installed to get my oil pressure sender clearing the filter had cracked at the block and was dumping oil out. EZ-Out and a new pipe fixed it all.
:hairrais: plz tell us where you got this pipe, and what its made of. brass or steel??? mine is brass, so I hope you dont say brass, lol
brass. it came from the drawer at work labelled "air fittings". Its just a 1/4"x3" pipe nipple that I imagine could be found in steel or chrome at a plumbing place.
On one of the tire fittings I actually have a 6" galvanized steel 1/4" pipe, so they do exist. Thinking about it, mine could be bronze instead of brass. Its darker than brass, but its probably also older than I am, so who knows.
