90 Temp Lever Nonfunctional
    I am a noob to the problems of the 90+.
    I've heard the HVAC controls give problems. In examining the 90, the temp level is stuck toward the cool side, and won't slide past halfway to the warm. This is something that can be fixed or do I need to pray I find a good used one?
    Also, the lever that controls position settings is okay but I hear nothing moving (car running).
    Finally the fan is not working on any speed/any position setting. It is getting 12v. Blower resistor problems I've had in the past, I still had high.
    This is not an ATC car.
    The usual issue with the 90-94 MGM/CV HVAC controls is levers that feel sloppy. Mr Bean fixed them on his '91 P72.
    In your case it could be a piece of the spacer broke and is jamming up the works. Just a different symptom of the same problem.
    The only unit I have ever taken apart, enough to get at those spacers, I wasn't concerned with putting back together. If you can find a unit at the JY to practice removing the face on I would recommend it.
      Thanks for the link. There is a fresh well used 92 in the local u pick that I could "practice" on. So it's the spacer right behind the visible part that could be the issue.
        For the temp lever it could be, and if so removal of the face is the only way to access those spacers. The face is held to the chassis (as best as I can describe it) by plastic pegs. When I removed the one I had I broke a couple of the mounting spots on the chassis. It went back together and looked fine but any time breaking stuff can be avoided you're a step ahead, so tear into that 92 at the yard to get a better idea of what I'm talking about. If the 92 unit is in good shape you can use it as a replacement.
        Also, since your wagon sat for an unknown amount of time without that small rear window it could be rust or corrosion (especially if the lever moves a cable, which I don't know if it does or not).
        For the position lever, if things aren't switching (you'll know for sure once the blower motor is addressed, maybe a dead motor?) it could be a mechanical issue beyond the control head.
          Have you pulled it out yet? Those levers are definitely weird back there... hope its not a broken/obstructed blend door! I replaced mine in the 91 because one lever went floppy, I only remember getting the cables loose being a pain. All three parts to them come off pretty easy though, in case you have to Frankenstein one.
          The vent selector is vacuum controlled, I'd check for leaks.
          If the fan is getting 12v, it's probably dead. Did you try smacking it like a bad starter?
            kinda why I did this: http://www.grandmarq.net/vb/showthre...ck-manual-HVAC
              Tried beating the fan motor. No Worky. Haven't pulled it yet - still checking on the parking brake. One project at a time on this beast since time to work on it is nonexistant. But will soon. I am wondering if anything in the dash is getting vacuum. Parking brake and HVAC could all be affected, and hearing not a hiss or a squeak from this thing has me wondering.
              I like. But I don't have the hole for it unless I ditch the radio. Or dash swap. Hmmm. Looks really good though.
