Pretty sure for the air temp. sensor i used a 9/16" bit and a 3/8" NPT tap. I think the suggested size for bit was 19/32 but 9/16 is close enough.
Going to an Explorer 302
you could measure the belt size you need with a piece of string and see what a part store has that way. just a suggestion-Phil
Question....how do you tension the belt then?~David~
what belt are we talking about? The alternator belt is the stock size, and the AC belt depends what hardware you're running. AC with no smog is a 56" belt.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postwhat belt are we talking about? The alternator belt is the stock size, and the AC belt depends what hardware you're running. AC with no smog is a 56" belt.-Phil
Originally posted by 86VickyLX View PostI'm going to be drilling out the boss for the Intake Air Temp Sensor, and the two ports for coolant fittings. Anyway, what size drill bits, and tap sizes do I need to do this?
Also, I'm going to run the engine on the engine dyno in school. I need to come up with a belt that will fit between only the water pump and crank pulley? Anyone have a belt size that might help me?
John, you car is going to be a beast when its done...haha. I'm pretty excited for you and Vicky, keep us updated!... i kinda wish i was there when you put the motor into her...-Phil
Originally posted by Brown_Muscle View PostJohn, you car is going to be a beast when its done...haha. I'm pretty excited for you and Vicky, keep us updated!... i kinda wish i was there when you put the motor into her...
Thanks FatNasty!! Would you happen to know what the size of the coolant ports in the back are supposed to be? I want those done too, and I'm not sure if they're the same size as the air temp sensor or larger.Last edited by 86VickyLX; 04-27-2010, 11:42 AM.
What do you need the ports in the back for?
If they are the same size as the one in the front for the gauge sensor its either a 3/8" or 1/2" NPT, leaning towards 1/2".
3/8 NPT sounds right. I've never actually checked though.86 Lincoln Town Car (Galactica).
Does an EGR coolant line run there? I don't have them hooked up on either car. Don't remember where they even went now.
Originally posted by FatNasty View PostDoes an EGR coolant line run there? I don't have them hooked up on either car. Don't remember where they even went now.
What's this about coolant weirdness in the upper intake?Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
