Oil change day. 74,263km. 446km on this oil, which is a mix of leftover mixed conventional 10W30 and 5W30 plus about a litre of Dex/Merc (re: the potentially false tale that ATF cleans up engines). It came out black as night, so there's that. This is the second oil change in owning this car; the first change was also a very short interval and happened after the timing set and intake gaskets right before it hit the road.
New oil is a Shell-manufactured synthetic blend diesel/HD 10W30 in a store brand pail. It's probably Rotella T5 but there's no way to really know that. New filter is a FL1A. This combo will run for a standard 4800km OCI. I put copper washers on the drain plugs as the plastic ones were leaking, as they always do.
The Citgo C1A filters ($1 filters I bought because I knew I'd be doing a couple short OCIs) seem to have a very functional anti-drainback valve. Maybe more functional that our beloved FL1A. The car had been left on ramps after the trans drain plug stuff above, and not run since, and yet when I pulled the filter it was completely full of oil and there was a significant suction/draining sound when I threaded the filter off (air entering). If I had a good way to evaluate how well they actually filter I'd be tempted to buy a bunch more if they're still on RockAuto.
![](http://i.imgur.com/1QhmWEQl.jpg)
Didn't do chassis lube since that was all done 446km ago.
