kishy's 1984 Town Car
    Next to branch off from My Rides is my 1984 Town Car, which is my current DD and the car of mine the most of you are most familiar with I'd guess.
    Acquired in May 2016 for $650 in barely running condition intended to be a plusher winter beater since my Ranger is punishment to spend much time in, but I like it too much to let the salt eat it now so I'm back where I started.
    There are pic attachments in the below original post:
    Well, you've seen me whining about the woes of wiring harness problems. Now it's time to meet the car!
    An irresistible deal on this '84 Town Car Signature (EEC-IV CFI 302) popped up, and I had to have it. May 2016 I bought it, coaxed it home running like crap, then followed the Ranger pattern and dragged my heels getting it ready until about November, lol.
    Prior to the Lincoln I did pick up a '97 Vic for parts, mainly its HPP wheels with new tires and the rear axle, but its powertrain might go somewhere silly like the Ranger, no reason other than availability. Not really deserving of its own post though.
    For the Lincoln:
    • Replaced starter (PMGR)
    • Oil change (first in a couple years)
    • Rad hoses, water pump, radiator, thermostat, coolant flush
    • O2, ACT, ECT, cap, rotor, plugs, wires
    • Intake gaskets
    • Valve cover gaskets (PermaDryPlus <3)
    • Compression checked out OK, 150 on all 8
    • Diff oil and verified very low play at axle ends
    • Replaced "choke pull off" diaphragm
    • Fixed climate control (bypassed thermal blower lockout & replaced interior temperature sensor vacuum valve thingy)
    • Trans/converter fluid and filter change
    • New battery terminals
    • Set base idle speed and timing (like 14 times)
    • Repack front bearings
    • Replace fuel pump and pickup strainer, and fuel filter again...
    • Timing set (double roller woot woot)
    • Repaired all the window motor gears with the eBay Delrin replacements
    • Replaced parking brake cables & rear wheel cylinders, flushed out entire brake system
    • Replaced driver side mirror because the motor was shot in the original and glass was hazed, and the junkyard motor I grabbed was an 85+ (turns out they're different).
      Then proceeded to back the mirror up into the Ranger, denting it.
    • Replaced hood struts. Twice. Still won't stay up. Damn steel hood.
    • Replaced all power steering fluid with stop-leak (pump leaks around shaft). Still leaks, so I'll be watching RockAuto for a $20 pump. Shouldn't take long.
    • Body work! Ghetto-fabbed some quarter panel repairs that go under the cladding. It was really the only serious rust to speak of on the car, but its severity more than made up for the lack of rust elsewhere. This isn't a concours car by any stretch so I really just needed a way to make it through safety inspection, and exhaust entry into the trunk is a fail.
    • Alternator blew up. Replaced with reman 1G and new regulator. 3G in the future.
    • PIP
    • CFI/Wiring harness fun! There's a break in the harness somewhere, and car is currently running with '85 Vic ECM and harness.
    • Installed near-flawless condition 1981 Mark VI bumper I found in the junkyard for all of 47 USD. As 1984 still has the vertical slats grille rather than the egg-crate one, it matches nicely with the mini-grille in the bumper.
    [ATTACH=CONFIG]46554[/ATTACH] [ATTACH=CONFIG]46560[/ATTACH] [ATTACH=CONFIG]46558[/ATTACH] [ATTACH=CONFIG]46557[/ATTACH]
    [ATTACH=CONFIG]46565[/ATTACH] [ATTACH=CONFIG]46564[/ATTACH] [ATTACH=CONFIG]46566[/ATTACH]
    [ATTACH=CONFIG]46568[/ATTACH] [ATTACH=CONFIG]46567[/ATTACH] [ATTACH=CONFIG]46569[/ATTACH]
    This car was a relative nightmare due to electrical gremlins. The evening of December 31 was the night I finally got it to what seems to be 100%, and other than fluid services and yesterday changing the battery and starter relay, I haven't had to work on it (knock on plastic wood).
    In January 2017 I was in a fender bender (other driver at fault) which broke a turn signal, fender extension, and damaged the already poor paint on the passenger side fender.
    I was not at fault, and insurance paid for the repair. In doing this I took advantage of the opportunity to do a Mark VI header panel swap I had been considering doing anyway and had all panels ahead of the A-pillars painted. This took quite some time to be completed due to delays with my insurance company but it got taken care of in the end, in April.
    In the meantime, RockAuto featured this car in the February 2017 newsletter with the photo taken just prior to the crash posed in front of Fisher Body Plant 21.
    The Mark VI swap is something I said I'd do a write-up on, but it's difficult because my implementation is a bit of a hack-job. Physically, it all bolts on no problem. The controls for the doors, on the other hand, are where I went a little rogue. I need to revisit how I did it and will most likely do a write-up once I fix the shortcomings of how I did it originally.
    Also in April I did the 130A 3G alternator upgrade:
    ...Picked up two junkyard '94 Taurus/Sable 3.0 Vulcan alternators with pigtails, which are the smaller 130A variety. I then extracted the charge cables out of two newer Tauruses, ca. 2002, because the cable is a lot easier to dig out of the newer years. The alternators were taken to AutoZone to be tested and both came back OK. One is for the Town Car, the other is for the '83, since poor idle voltage makes the sequential turn signals angry.
    Townie's upgrade is done minus ground upgrade; I'm not sure it's truly necessary but will get to it sooner or later. I didn't go 3G to get more juice out of it overall, just to get more out of it at low RPM specifically.
    Took apart my harness, eliminated the charge wire and everything relating to the external regulator. Spliced the choke cap wire into the stator wire (in retrospect should have fused this in case of a short, but Ford didn't see fit to so I'm sure it's fine). The internal regulator wants to get battery (+) on one of the wires; for this I just looped it back to the charge wire stud. Alternator is fused with a 150A ANL fuse, which I figure exceeds the highest output I might try to suck out of this thing.
    I have previously found that a "50.7" inch belt - 6K507, K060507 - fits this exact alternator when installed in my '91 Grand Marquis. I don't know why, but that didn't work on the '84. Something to do with the other pulley sizes I guess. I tried notching the lower bracket so the alternator could swing over further, no go. Ended up swapping the pulley which isn't a solution I like because it means a roadside swap in case of failure is impossible, but whatever. Thankfully I have air and an impact gun, otherwise I'd have had to abort and put the 1G back...
    Alt vs alt:
    Stock harness (85 LTD CV; 84 functional equivalent; LTC has extra wire for oil level)
    Laid out left-to-right as it sits in the car
    Altered harness (same as above, with alternator stuff removed, except the wire to the light in the cluster)
    Fuse
    Tada!
    Obligatory posing shots:
    And something from today:
    Current driver: Ranger
    I like that the 80-84 TC's got two light bulbs in the taillights..
      I thought the 85-89s did also? It would keep in line with what Ford did on every other Panther: 3 dual filament bulbs that light up with the turn signals.
        Nope, just the one, cheap bastards.
          Vinyl tops strike again!
          Water is entering my trunk from somewhere under the vinyl top in the vicinty of the bottom right corner of the rear window. Trunk seal is definitely dry and the entry is not at the seam around the trunk opening, it's 100% from up above under the vinyl. When transporting the wagon windshield with my buddy in the back seat he noticed the tell-tale "sloshing" sound going around corners, so water is accumulating and staying somewhere back behind the package shelf.
          Stop-gap is going to be siliconing the vinyl to the glass, long term there's probably body work to be done and as much as I hate the thought of it, maybe slicktop this car.
            Since a slicktop Town Car was never a thing I've heard they look goofy. Dunno, wonder how yours will turn out though.
              single bub 85+
              there are weird body lines under the top. You'll find them. The plastic filler panel in the back corner is especially cute.
                Somehow the notion that Ford cut corners to the extreme because they knew they'd all get vinyl tops doesn't surprise me even a little bit. I also imagine that the Frenched rear window is in fact only as big as it looks, and doesn't extend out too far beyond the current edges of the vinyl, meaning it'll just look stupid without it. Or even if the glass is full size (consider the base models had more glass surface area) the defroster grid is probably sized to the smaller window shape.
                I like the vinyl, if I can replace it in a cost-effective way I will. I just don't really know if that "cost effective" part is possible.
                I find the single-bulb cheapness kind of curious...maybe they discovered a reason why the dual bulb setup wasn't such a great idea. Too much heat causing lenses to separate?
                  sure its not coming in around the trim that goes along the bottom edge of the vinyl? There are little studs that poke into the trunk through a blob of that black tar sealer goo. If that shrunk up, water will just run around the stud and drip in.
                    I'm not sure of the entry point. The horizontal metal in the area of the trunk hinge gets wet, I don't know where it comes in from exactly. I think it's possible though.
                    Unfortunately one of the headlights burned out, and do you think I can find a pair of H5006 anywhere locally? Of course not. Might go with conversion housings, but quality is spendy (think Cibie). The headlights on the car now were installed on the header panel when I got it, so I can't really say I didn't get my money's worth out of them.
                      We still stock plenty of sealed beam headlights at work (H5006s for a fact), but the glaring issue is being stateside and incredibly far from the US/CAN border.
                      Honestly swapping over to an E-Code housing would be of major benefit. That's something on my to-do list, but I just haven't gone out of my way to do so. There's a seller I see on eBay that sources through Autopal. The Autopals look like Hella housings, but considerably cheaper. I looked around at a few other forums to see if anyone had experiences with them, and a good number of folks indicated the Autopal housings were reasonably constructed for the price. Metal reflectors and glass faces. Toss in a relay upgrade if you haven't done so and I'm sure you'd be good to go with those.
                        Yeah...I have a set of Autopals to put on the Ranger when one of its lights burns out. I'm not opposed to them, but I've seen the occasional mention that they're bad for hotspots or the cutoff seeming too low. But, still worlds better than sealed beams, so maybe that's worth some consideration.
                        Summit sells the Hellas for reasonable prices, but after shipping, I can get them cheaper from Autozone which sells them for ship to home only but has a free shipping promo right now plus a 10% discount code I found. Ship them to my buddy's house and pick them up probably on the 30th...$55 USD for the pair. Significantly more than sealed beams but also significantly better.
                        This car is relay re-wired, but using largely factory wiring except the new wires from the battery to the relays. I was just trying to take the load off the headlight switch, not necessarily improve anything otherwise.
                          I saw a Town Car that someone scalped and yeah, there are weird body lines at the window and I think you're right about the defroster grid not going the entire length of the window, it's like sized to the top. If a slick top Townie was a thing I'd like one but I absolutely dig the half top that was standard. Well, at least on the Signature Series cars. A full length shitty vinyl top was base but even a lot of the base model cars got that half top treatment.
                            Opted for Hella housings from Summit Racing shipped directly to me, no US proxy. The Autozone solution would have taken longer as my preferred border crossing is closed until Nov 4 for maintenance (ceiling replacement in the tunnel).
                              I was going to ask wtf you were talking about with the roundie lamps, then I remembered you have a Mark VI front end.
                              Full top is cheaper than half measures to replace. Its one piece of vinyl and no headliner removal. The half top is I think 5 or 6 pieces plus the headliner comes out. One for the roof, the rest are on the "belt" itself which is apparently a giant pain in the ass to re-do. One thing I do have that you don't is very difficult to find rear window trim. The half tops frenched in the rear glass, I have all of it with chrome trim that only the cheap of the cheap cars got.
                              On the upside, that rust hole that got repaired with a new A pillar is perfectly hidden under the top. The bodywork under there isn't flawless but since there is vinyl over it there wasn't any need for it to be paint quality.
