Originally posted by jaywish
View Post
Originally posted by mitymerc
View Post
Bumped the idle. Cold weather was making 2-footing necessary until it warmed up. Some day, I'll fix the cold idle bits. Still a bit ticked off about those screws breaking off.
Last night, added a 4-flat trailer connector. Pulled all the driver side rear quarter plastics out and tapped in (solder, not crimp splices) in the driver rear corner. Would prefer everything to be relayed, but I didn't feel like pulling a new wire back from the battery. There's a looooot of car to cover in between. Not sure how the factory tow wiring works, this car doesn't have it. EVTM is MIA. I'm suspecting there's a whole sub-harness that probably starts somewhere near the fuse panel on cars so-equipped.
Oil sprayed the inside of the quarter panel...I was there anyway and it's kind of irritating to access so it made sense.
![](http://i.imgur.com/1xL1GdZl.jpg)
![](http://i.imgur.com/vZYg0FAl.jpg)
![](http://i.imgur.com/pD7Elggl.jpg)
Test fitted the Ranger Trailer using a typical drawbar, flipped to rise instead of drop. Fits close...pretty much ideal really. The ball is as close as mechanically possible to the hitch mounting points.
![](http://i.imgur.com/WUtjxvql.jpg)
![](http://i.imgur.com/6zRywpKl.jpg)
