Transmission pan leaking RTV?
    To check the gasket for splitting like I described you don't have to take the pan off. Just get the car high enough safely that you can get under it entirely, and inspect with a light around the outside. If you see the gasket bulged out and with a crack in it near the source of the leak, you've found your problem.
    The cork/rubber mix gaskets are probably best for this application. They suck for some things (valve covers...) but they seem to do fine for this, plus they're a little more flexible I think.
    Current drivers: wagon + 91
      That's what I figured, cork does seem to have more give.
      Would you use rtv/black rtv/copper ultra for this application for cork?
      -1973 Volkswagen Bus Westy
      -1986 Honda Magna 700cc
      -2011 Subaru Outback
        I always use The Right Stuff. Comes in a caulk tube looking thing. Expensive at $20 a tube, but never had any leaks after using it.
        Nick
          I just don't use sealers on things most of the time. Clean mating surfaces and decent quality gaskets work for me. Cork gets puttied up with RTV because cork sucks ass. Rubber gaskets go in dry. Very careful prep of the sealing surfaces is a must though, otherwise its just not going to work. Steel pans sometimes get some bodywork to make them flat and true, machined surfaces get scraped clean, filed flat if needed, and wiped down with solvent. High spots and gouges are where gaskets just don't work.
            Originally posted by blkpnthr View Post
            Following torque specs has squished the rubber gasket out and split it 3 times for me so far. Learned my lesson. I do the bolts up until the gasket starts to try to squish out and call it good. ...
            ... and if it's got threads it gets anti-seize. ...
            I'm wondering if the anti-seize might be why you're having problems with the gaskets. AFAIK, torque specs are for threads without anything on them. When you put something like anti-seize on the threads, you get less friction. By the time your torque wrench feels enough resistance, you might have gone past the intended depth. Based on what I've seen in the past, I think you're supposed to reduce the torque by about 25% if using anti-seize.
            The torque spec should be getting you to the point you describe where the gasket starts to squish out. Something else to remember about torque specs in an application like this one is that you want all the bolts relatively uniform. Normally, I would torque things like this in stages, using the proper pattern of course. So, if the max specified torque was 10 ft-lbs, I might do hand tight first, then snug, then 6 ft-lbs, then 10 ft-lbs.
            And I see gadget just made a great point about properly preparing everything. When I do work on my car, I kind of view things like this as performing surgery.
              That was more of a generalization...the trans pan bolts aren't anti-seized lol. The water pump bolts, on the other hand...
              Definitely should have clarified that. Do NOT anti-seize the trans pan bolts.
                You would use this "Right Stuff" with a cork gasket?
                Where can you get this at, Home Depot? Autozone?
                  I have on numerous occasions. Always seems to work for me. I picked mine up at Advance Auto. O'Reilly's, Autozone and the like should also have it.
                  Nick
                    Pretty sure they recommend no rtv with rubber gaskets.
                      I use the moroso transmission pan gasket. It's basically like a felpro permadry gasket for valve covers or oil pan. The disclaimer on the page says that it's not for use on a stock steel pan. But I have not had any issues with it leaking at all. And, it's reuseable.
                        Is moroso on ROckauto?
                        And I thought stock tranny pans were aluminum?
                          stock pans are galvanized steel.
                            Oh, ok, ideally, i would like to have the pan that has a drain plug. Would be easier to change the tranny oil
                              summit. you can add a drain plug to yours.
                                Most places carry the plug kit. I brazed mine in on the Mark VII, but the washer works fine on the Towncar. Ivan replaced the plastic washer with copper. The plastic didn't leak, but he swears the copper is better. I have no opinion on the matter.
                                'nother thought, if the pan lip is tweaked, it won't seal right either. I had to do some bodywork to the pan on the Mark VII. When I had it at work to punch the hole for the drain plug, I noticed that around the bolt holes the pan wasn't flat anymore. A few minutes with a small hammer and a chunk of metal in the vise for a dolly fixed it just nicely. Its currently using the fiber gasket, which looks all the world like heavy gasket paper dipped in varnish, but its not leaky.
