84 colony park, ignition switch rivets?
    Hi everyone, quick question: i need to replace my ignition switch...1984 colony park wagon, looks like it's riveted onto the steering column is that right? If i drill them out, i have to rivet it back on? Is there another solution? Thanks!
    1984 Mercury Colony Park Wagon - gone to the darkside. 5.3 LS Turbo Swap with 4L80E. 6.62@106 in the 1/8 mile (low 10's in the 1/4), full weight, AC, no compromises! Rocky Mountain Race Week 2020 and Race Week 2.0 2020
    I thought they were Torx screws, but I’m not sure about the earlier models.
      They should be T30 and may be "secure" T30 (with the pin in the middle so you need the bit with the hole in the middle). Maybe a T20 or T25. They should also be some obscure fine thread bolt. Don't lose them.
        They aren't security Torx, but I've seen junkyard cars that had security Torx which I believe are replacements that come with some new switches. The factory ones are special security screws with a head that kind of resembles a rounded off hex head, but super tiny. The best way to turn them out is with vice grips grabbing the outer edge. Do not try to engage with the nub in the middle, it won't turn by that.
        Some of the new ignition switches include new screws, some do not. It's a pretty normal machine thread, can't think of what it is off the top of my head, but I had spare bolts in my box of random hardware that fit when I've had to do it before.
        Current drivers: wagon + 91
          yeah, that sonsabitchin thing. If you have a set of sockets meant for removing stripped bolts, those work well. A Dremel to cut a slot is also an option. I did this just a few weeks ago on my 84, and my 86 Towncar had them too.
          Last switch I installed did not come with screws, but the parts store had license plate screws that were a large phillips head in the proper thread. Its an M6 I think, nothing strange. Hex head would probably also work fine.
            Dang it, i should've waited another hour for more replys, i drilled 'em like rivets. Now I've gotta drill and tap for new screws. What an asinine design. For what its worth, i tried to grab 'em with vice grips but no luck...should grabbed the outside ring. Oh well.
              Its a great design for assembly purposes, but a shit one for service. Assembly you just run it in and it snaps the driver off when it gets to whatever design torque is. It usually lasts out of warranty, so who cares if its annoying to replace 30 years later.
                Ha, very true. plus I found out mine is still working perfectly 34 years after assembly!
