Page 1 of 2 12 LastLast
Results 1 to 20 of 39
Thread: Driveshaft or U Joints?
  1. #1
    GMN Regular
    Aug 2018
    808
    Default Driveshaft or U Joints?
    I took a video but you canít hear the noise so Iíll try to describe it. On my 87 mgm thereís a vibration through the body pretty much at anything above 30 or so. Now when I get to about 60 it starts to vibrate worse and thereís a hum. Itís sort of like a week bearing hum but it comes on within 5 mph and increases with speed and instead of a steady hum itís like it oscillates. I know Iím not the best at describing noises but thatís the best I can do. I have u joints on standby as Iím sure the ones on it are original but could it be the driveshaft itself?
  2. #2
    Sep 2014
    Warren, MI
    6,590
    Oscillates. That sounds like a bad u-joint to me. They kind of pulse. If it was the driveshaft, the whole dash would shake and all that.
  3. #3
    GMN Regular
    Aug 2018
    808
    Iíll do the u joints maybe this weekend when I have more time off. Yeah itís like a pulse and it comes on quickly instead of a wheel bearing sound that starts off at low speeds and gradually gets louder. And I couldnít change the sound when I would steer the wheel either way so Iím sure youíre right.
  4. #4
    GMN Regular WagonMan's Avatar
    Sep 2004
    Bridgewater Ct.
    832
    A good indication of bad U-joints is a major "clunk" when shifting from drive to reverse. Any noises then? WagonMan
    1990 Colony Park
    1970 HEMI Superbird
  5. #5
    all the CFI are belong to me
    Feb 2014
    Windsor, ON, Canada
    2,105
    Quote Originally Posted by WagonMan View Post
    I will +1 this but I will also note that U-joints can be bad, and still tight.
    I would also guess that most of these cars by this point have a little bit more lash in the diff than they originally did, which can contribute a clunk, so a clunk also does not guarantee the u-joints are bad.
    Specifically, when the bearings in the U-joint dry out and start to seize up, the joint can be tight, but it does not move smoothly on the bearings, so it vibrates as it fights changing angles through the dry bearings.
    If it gets like this, it can be totally silent from inside the car, but might make a slight squeak-squeak-squeak noise when just idling forward in gear as it rotates.
    U-joints kind of suck to change but they aren't super expensive, and if their history is unknown, I'd just change them if it were me.
    I still have a wicked vibration in the wagon, at much higher speed than you, which I believe is coming from somewhere in the rear end. Keep in mind there are several bearings back there which can and do wear and fail, so your problem could be back there.
    If you can safely support the car in the air and let the engine idle in 1, with wheels turning freely, you might be able to get a better feel for where the noise is coming from which will help tell you where the problem is. This is extremely dangerous though, the risk of the car dropping off whatever you put it on is higher with the wheels spinning, and the risk of damage or injury if it does fall is also higher with the wheels spinning.
    Current driver: 85 Ranger
    Panthers, Parked: 83 GM 2dr POTM 10/2019 | 84 TC POTM 1/2017 & 4/2019 | 85 CS | 86 GM | 88 TC | 91 GM POTM 12/2017
    Not Panthers, Parked: Ranger trailer | 05 Focus | 04 Focus
    RIP: 97 CV | 83 TC
    Junkyards
  6. #6
    40,850
    Pulling the driveshaft and running the joints through their full range of motion will tell you right quick. If its notchy or stiff at all, its done. It should move smoothly through the full arc of motion with no sign of hangup.
  7. #7
    GMN Regular
    Aug 2018
    808
    I donít have anywhere to safely put the car up on stands but that would be a great idea. And good call on the rear suspension. Iím sure itís all original, is there anywhere that sells rear control arm bushings for these cars?
    Wagonman, no thereís no thud going into gear.
    Gadget, itís easy enough to pull the drive shaft and change the u joints so yeah I think Iíll do that and check for stiff bearings. That was my thought as you and Kishy pointed out. The car has unknown mileage and I know has a few periods of sitting so Iím sure thereís bound to be something stuck.
  8. #8
    I post a lot...
    Dec 2011
    Yonkers NY
    4,400
    while it is out make sure the shaft is true.
  9. #9
    40,850
    and do not put the slip yoke in a vise. Someone did that on my car when the U joints were changed before I got it. Couldn't ever get the damn thing to not leak at the tailshaft until I actually inspected the yoke and found the vise teeth marks on it.
  10. #10
    Donating Member massacre's Avatar
    Oct 2011
    USA
    421
    Wow
  11. #11
    GMN Regular
    Aug 2018
    808
    Some people just shouldnít work on carsÖ
    And yes Iíll definitely check to see if itís straight and the weight is still there.
  12. #12
    Sep 2014
    Warren, MI
    6,590
    Ashley's '89 did not clunk when put in gear. However, it had a pulsing vibration that started around 65mph and got pretty noticeable at 80. Front U-joint was bad.
  13. #13
    GMN Regular
    Aug 2018
    808
    Thatís pretty much how Iíd describe it. And has a humming sound too like those trucks with the big tires.
  14. #14
    40,850
    joints have to be really bad to have enough slop to bang. usually means the needle bearings have completely disintegrated. They get dry and start binding long before they turn completely to powder. Its one of those deals where if you ignore it long enough eventually it will start to bang but very unlikely it went from perfectly fine to making nasty noises with nothing in between.
  15. #15
    Sep 2014
    Warren, MI
    6,590
    U-joints have to be really bad to have enough slop to bang...
    This.
  16. #16
    Stow It! GM_Guy's Avatar
    Sep 2008
    Ontario, Canada
    3,519
    Might not hear it over the exhaust if its non-stock in the early stages. BTDT.
  17. #17
    Mar 2010
    Lewisville, TX
    22,607
    Also, if the u-joints are seizing up, they won't bang either.
  18. #18
    GMN Regular
    Aug 2018
    808
    Since I have you guys here I have another question but itís about brakes. My 85 ltd had awesome brakes, this car does not. Theres resistance but I have to press them Iíd say about 3/4 the way to the floor to stop. And they have locked up on me when braking moderately but I didnít feel like it should have been at that point if that makes sense. Itís like a light switch, itíll brake normally most of the time though. And the pedal is slow to return to the up position. I can take my foot off it when itís at the bottom of its travel and itíll take a few seconds to return to the top.
  19. #19
    40,850
    ever inspect the rear brakes? Most of them haven't been touched in decades. If they aren't working right the braking gets far worse than it should be.
  20. #20
    GMN Regular
    Aug 2018
    808
    No I havenít, though Iím sure theyíre old like everything on this car.
