Might not hear it over the exhaust if its non-stock in the early stages. BTDT.
Driveshaft or U Joints?
Also, if the u-joints are seizing up, they won't bang either.
Since I have you guys here I have another question but it’s about brakes. My 85 ltd had awesome brakes, this car does not. Theres resistance but I have to press them I’d say about 3/4 the way to the floor to stop. And they have locked up on me when braking moderately but I didn’t feel like it should have been at that point if that makes sense. It’s like a light switch, it’ll brake normally most of the time though. And the pedal is slow to return to the up position. I can take my foot off it when it’s at the bottom of its travel and it’ll take a few seconds to return to the top.
ever inspect the rear brakes? Most of them haven't been touched in decades. If they aren't working right the braking gets far worse than it should be.86 Lincoln Town Car (Galactica).
yes all the brakes must work correctly but I also really suggest Centric Extended Peformance pads. They tend not to bind up as easily and don't really fade much.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
and if you haven't, see what sort of shape the front slider pins are in. If those are crusty the calipers won't move correctly and it will only stop on one pad.86 Lincoln Town Car (Galactica).
Yup. The brakes usually need attention to detail to make them all correct. Clean all the contact point rust, new adjusters and proper lubrication. Though I usually found that self adjusters are problematic. Even on the newer cars with drums.
The big brake upgrade is one of the best overall modifications for these cars. Along with good tires, sway bars and better headlights. It is often a lot of money to do all that but it changes the whole vehicle without hurting the luxury feel. If you are lucky you might be able to find a JY vehicle with a new suspension/brakes and swap the whole thing. That would save quite a bit of money.
If we are talking brakes probably the most important thing is new brake lines.Last edited by jaywish; 10-17-2021, 12:43 PM.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Didn’t have time to work on this but I’ll try here soon.
Good to know about those pads. I think I got stock pads for when that time comes. I’m not opposed to the big brake upgrade but I want to keep my turbines. I have a new set of hoses too just haven’t installed them yet. I have a big parts stash I’m sitting on.
Originally posted by 87GrandMarq View PostI’m not opposed to the big brake upgrade but I want to keep my turbines.
But you can also rebuild it to be like a 95-97, which offers some of the benefits of the newer system. Better sliders, for one. Sealed hub-rotor (no adjustable bearings).
It also makes the car ready to accept the 98-02 brake upgrade with less effort because the ball joints and knuckle can be kept the same.
95-97 will fit under 15" wheels.
Post #13
http://www.grandmarq.net/vb/showthre...ase-Read-First!
the later 2 diaphram booster will definitely give you more braking force with less pedal effort. However that won't fix the undersized rotors, or lack of the latest and greatest pad formulations. I think i'm one of the few people who have done the "medium" brake upgrade. They're nice, still undersized, however I intend to go big brake when i get new wheel and tires, i also changed to the later boosterLast edited by Brown_Muscle; 10-19-2021, 08:50 AM.-Phil
Originally posted by Brown_Muscle View PostI think i'm one of the few people who have done the "medium" brake upgrade. They're nice, still undersized, however I intend to go big brake when i get new wheel and tires, i also changed to the later booster
The car stops very well. Very very well. Zero wish for more braking on that one. A bajillion times better than stock box stuff even when it's all brand new. Stock box stuff is very "on/off", there is a threshold where the fronts just lock.Last edited by kishy; 10-19-2021, 11:10 AM.
Kishy, you gotta drive my '88. Everyone complains about box brakes but I don't mind mine one bit, I think it stops fairly well. Not saying I wouldn't notice an improvement if I upgraded, but I've never had an issue with front or rear lock and I've never had to panic swerve out of the way. Can't say the same for the people behind me though.1985 LTD Crown Victoria - SOLD
