The answer to this is probably hiding in plain sight, but I am struggling with search and not finding it.
The '91 has a sporadic issue. Probably 30% of the time I try to roll the rear window down with the key (from outside the tailgate), it doesn't work. Usually when this happens, the interior switch on the dash also doesn't work. The rest of the time it works, and works well.
Assuming a bad ground or short somewhere, probably where the electronics pass from the body to the tailgate itself, but is there a common place they fail where I should be starting my search?
Thanks in advance.
Thanks in advance.
