LTB Coil harness
Are there any junkyards near you? Many, many Fords used that coil and therefore the same connector, I doubt it would cost more than a dollar or two if they even charged you for it.
I know the second gen Taurus, which is very plentiful in yards due to its fantastic transmission, has what you want.
RockAuto has that plug. Solder a brand new one on instead of using another one that is old and brittle.1990 MGM: $50 E7 heads, HO cam, Holley SysteMAX lower intake, HO upper intake with an Explorer TB. LSC ECM. Lincoln logs into stock dual exhaust. K&N drop in air filter. Wide ratio AOD, 2400 converter with a 3.08 one tire fire out back. Car is less slow now. Then there's the '92 Beater. Dual 2.25" exhaust with shiny tips. Rumbles nice. Super slow. Burns oil too.
