Box rear sway bar
    Let me know if no one wants it, cause i'd like to buy it. thanks
      Originally posted by WagonMan View Post
      It measures 1 1/6". WagonMan
      and 1" for the rear bar
      -Phil
        Under "normal" driving conditions (not "spirited" driving) do front or rear sway bars really make a real difference or is the feeling merely psychological?
          If you have cloverleaf interchanges where you live, the presence of a rear bar increases the speed you can take the curve at with confidence. Whether this is a good thing or not, is a different story.
          My Lincoln got the big bars, front and rear, and it was like driving a different car before/after. It still has body roll, of course, but not nearly as much.
          Standard city driving? All it'll do is keep the inside rear corner from lifting as much in turns. Depending on your driving style you may not notice a meaningful difference. I take turns reasonably aggressively and I certainly noticed it.
          Current driver: wagon
          | 88 TC | 91 GM
          | Junkyards
            +1 If you experience rear wheel spin when cornering, thicker bars help keep the tires planted since it reduces body roll. If you don't change the springs, regular roadway feel (bumps and such) should be the same.
              Yup the Lincoln is a different car with a bigger rear bar and better meats. As sly said unless you alter the springs and maybe put in stiff shocks it does not make the ride harsh.
              One note of caution a very heavy sway in the rear without a good sway in the front can lead to oversteer in extreme conditions. That is counterintuitive to me but you can check it on the Addco sight iirc.
              That said it never happened when I added a police spec rear bar to the wagon and upgraded the rear wimpy TC sway to heavy Addco unit. I guess the existing front sways were heavy enough to keep the cars with slight understeer.
                My car had a decent sized front bar and nothing in the rear. Taking curves on the highway to Post gave enough body roll that I felt the need to slow up a bit. After installing the smaller rear sway bar that roll was pretty well taken care of and I could cruise through those same curves at speed.
                That's not a very scientific result, and I'm hardly Mario Andretti when driving the Town Car. But even without doing a lot of spirited driving I felt enough of a difference to recommend the rear bar. And that wasn't even with the bigger, police bar. Anything back there helps.
                  yes i find it difficult to understand how ford thought it was not worth the extra money to put them in everything given the obvious handling improvement.
                    Originally posted by Kaysboat View Post
                    Are you still looking for this? My parts car probably has one (has the trailering package). I can measure the diameter in the next couple of days.
                    I wish, car was totalled on bad roads 1/1/22
                    1987 CV LX 5.0
                      Most likely was an economic decision.
                        Had a look and my parts car does not have a rear sway bar. Weird as it has the trailer package (I think. Has a transmission and steering cooler, and a big hitch), but definitely no rear sway bar.
                          can you still get the addco rear bar?
                            They still have front and back.
                            92 and up rear 1" $271
                            02 & up front 1.25" $276 IIRC this would work with the big brake upgrade.
