As some of you may know, when you search upper control arms and upper control arm bushings for a 98-02 Crown Victoria they list the arms and the bushings specific to Police or Civilian. I don't want to get into the 92-97 police vs civi arms/bushings information, and as you can see below, the stupidity is only further amplified when you realize that Ford lists the same upper arm for 95-02. I am well aware that some time in 95 they stopped using the shaft kit in the upper arm and began using the frame mount which explains a difference in the parts listings, but still doesn't explain why the difference in police vs civilian. As far as 98-02 listings, Rock Auto and Energy Suspension both list different part numbers for the bushings, Ford lists different part numbers for the arms.
I don't know why, because I am looking at a pair of 00 Town Car right next to a pair of 00 Police interceptor arms and I see absolutely no difference in the arms nor the bushings. I am going to get pics shortly if anyone would like to chime in now.
Energy Suspension gives no reason as to why they list their bushing kit 4.3162 strictly for the Civilian car siting that they have not tested/designed for the Police/Taxi.
Ford lists their part numbers as follows. (To add confusion, notice how they list arms for the Police/Hpp and not the Taxi? Usually it's Police/Taxi and the HPP falls under a Civilian package.)
Civilian 95-02
Driver:F7AZ-3084-AA . (LH170 Stamped on Arm)
Pass: F7AZ-3085-AA. (RH159 Stamped on Arm)
Police and HPP 95-02
Driver. F7AZ-3084-BA. (LH161 Stamped on Arm)
Pass. F6AZ-3085-BA. (RH164 Stamped on Arm)
http://www.idmsvcs.com/2vmod/suspens...ont/index.html
Civilian 95-02
