I have a new heater core that i never put in the first '90. Should i have that done when the new engine goes in? Not sure the age of the one in there.
EEC-IV speed limiter
replace it when it fails. It comes out from inside the car, so engine in vs engine out honestly doesn't make any difference. if it doesn't fog the windshield and stink like coolant though, let it ride.86 Lincoln Town Car (Galactica).
I’ve replaced two, one in my old 85 cv and my current 87 mgm. Neither was that bad and can be done with just one side of the dash unbolted. Getting everything lined back up can be a pain since doing it that way you have to kind of angle the front up. If there’s any coolant left in the heater core it will spill. The po of my 87 was nice enough to cut out the carpet all the way to the seat so there was nothing for the coolant to soak into lol.
Originally posted by gadget73 View PostIts not the end of the world pulling the dash. I've done mine twice. The first core I put in was bad out of the box. Only real trick is to not hurry so nothing breaks.1985 LTD Crown Victoria - SOLD
Originally posted by NotYourFathersMercury View PostUpdate on this, they do have a speed limiter. With 4.10s you will hit it going 67mph. Unplugging the speedometer from the transmission fixed the governor, and I just use the tach speed to guestimate the MPH
My Cars:
I'm pretty sure that's not a limiter that's just the end of the world with the 4.10's and a !:! third gear. You're not getting into overdrive at wide open throttle. I had my stock '88 with 3.08's up to a GPS verified 111 in third gear on a flat road. If you had unlimited road and could accelerate in OD lightly enough that it didn't downshift you might get faster. There's online calculators that show how fast you could theoretically go based on RPM, gearing, and tire size, I say theoretically because of aerodynamic limits.
Originally posted by 87GrandMarq View PostI have 4.10s myself and can’t imagine going above about 65. Between the vibrations and howling noise of the drivetrain I’m scared it’ll come flying apart lol. But I don’t like driving it that way anyway, it’s a cruiser not a racecar.
Sent from my iPhone using Tapatalk1985 LTD Crown Victoria - SOLD
Originally posted by mercurygm88 View PostYou're not getting into overdrive at wide open throttle.
Originally posted by 87gtVIC View Post1990 Country Squire - weekend cruiser, next project
oddly enough the ZF box in my diesel will run OD at full throttle.
and yeah a well sorted box will do well north of 100 without feeling sketchy. Driveshaft vibes are very uncomfortable though. My original one had issues.86 Lincoln Town Car (Galactica).
Originally posted by Tiggie View Post~6300rpm? I would have lifted too. I don’t know a lot of 302’s that like more than that without expensive parts or borrowed time.
From my RR Spotlight page:
Engine:- New LMR 5.0 302 V8 (SEFI) with Forged Pistons (LRS-6009EF)
- HO Conversion with A9P
- Tuned by Willie at Dirty Dog Racing with a Moates Quarterhorse
- Mass Air Conversion using 2008 Crown Victoria 80mm Slot Style MAF
- Trick Flow 170 Twisted Wedge Cylinder Heads (TFS-51410004-M61)
- NGK FR5 Spark Plugs gapped at 37
- ARP Cylinder Head Bolts (ARP-154-3601)
- Trick Flow Push Rods (TFS-21406700)
- Trick Flow Stage 1 Camshaft (TFS-51403001)
- Trick Flow 1.6 Roller Rockers (TFS-51400510)
- Trick Flow Double Roller Timing Chain (TFS-51478520)
- Ford Racing Roller Lifters (M-6500-R302)
- Ford Racing Harmonic Balancer (FMS-M-6316-M50)
- ASP Racing Aluminum Underdrive Crank Pulley (ASP928900)
- 24LB Denso Blue Top Fuel Injectors
- TMoss Ported GT 40 Lower Intake
- Lightning GT 40 Tubular Intake
- Lightning GT 40 Tubular Intake Plenum Plaque
- Lightning EGR Spacer
- Lightning 65mm Throttle Body
- Trick Flow 3/8” Phenolic Intake Spacer (TFS-51520017)
- Trick Flow Valve Covers (TFS-51411801)
- Trick Flow Oil Fill Neck (TFS-51400800)
- SVE High Torque Mini Starter (LRS-11002B)
- ICT Billet EGR Delete Plate (551604)
- TAB, TAD, EGR and Smog Delete
- McCully racing Motors TFI (Thick Film Ignition) Relocation Kit (Mounted on Core Support)
- ARP Oil Pump Drive Shaft (154-7904)
- NOS Ford Metal/Rubber Valve Cover Gaskets
- 1990 Ford LTD Crown Victoria Drivers Side Inner Fender with Plastic Vacuum Reservoir/Relay Combo
- 2006 Ford Crown Victoria Police Interceptor Air Intake Box
- 2006 Ford Crown Victoria Police Interceptor Zip Tube
- K&N High Performance Air Filter (33-2272)
- Ford Racing 9mm High Performance Spark Plug Wire Set (M-12259-M301)
- Spark Plug Wire Separators
- MSD V8 Cap and Rotor Kit (8482)
- Billet Specialties Ball Milled Wire Loom Holder (69520)
- New Duralast Engine Coolant Temperature Sensor (SU201)
- New Motorcraft Fuel Filter
- New Duralast Alternator Belt (505K6)
- New REM Reproduction UnderHood Hood Liner (FM-753)
- New DEA Engine Mounts (A2437, A2438)
- Walbro 190 lph Fuel Pump
- 1985 Ford LTD Crown Victoria 351 Oil Cooler Set up with replacement Derale 15405 Cooler
- Moroso Oil Seperator Kit for PCV System (85481)
- Moroso Oil Seperator Kit for Valve Cover Breather Tube (85632)
My 93 will theoretically do 140 at the top of 3rd (what it hits on the dyno). I would be afraid of going over 110 unless I knew the condition of the road for the entire stretch I was going that fast. It has no issues cruising between 90 and 100 all day though. The box with the stock lopo and 3.55 gears hated going over 80mph. And towing the trailer was best done at 60 or below. The 93 will tow that trailer at 75 without breaking a sweat.
