1988 Lincoln Town Car
    Cool beans. Burn some rubber.
      Heater core #5 died yesterday. It's not exploded but a dribble is leaking out of the plenum and steaming the windshield enough to annoy me.
      Rock Auto only has cheap cores in stock now, really conflicted about what to do. Tempted to try one of these:
      http://www.thebrassworks.net/shop/He...578aee373c0d8f
      Has any of ye ever tried these in the past? If so, is it worth the money?
      Summer car-> 1988 Lincoln Town Car, triple blue, 335,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
        I lack the history of the other ones and their failure modes, so forgive me:
        I think that assuming "cheap ones are bad ones" is not the best approach. Also consider that RockAuto pricing will always be "cheap" because that's how they roll. I also think that buying a soldered brass/copper heater core (for incredible money) is a mistake, when it is an established fact that they don't last as long as aluminum ones. The caveat is aluminum ones are less friendly to some flushing chemicals and if you are the type to flush the system every couple years, you can quickly murder your new investment.
        I am also reasonably sure the one you linked will not fit. I believe that's the 90+ item with a common application data error which suggests it fits 89, but 89 uses the old one.
        Frequent heater core failure is probably more a symptom of a bigger systemic issue than it is an indicator of heater core quality, IMHO. You might have issues like electrolysis eating the core material away.
        | Junkyards
          Do you have a coolant pressure restrictor in place?
            Check the voltage in the coolant. If you've got some electrical grounding problem, you may have electrolysis going on and that will dissolve the heater cores too.
            https://www.northernfactory.com/knowledge/electrolysis
            Normally the heater core and radiator are not connected to electrical ground on these, so make sure nothing has changed in that regard. Missing or crusty battery to body or engine to body grounds can cause you trouble though.
              I actually had much better luck with brass cores vs aluminum ones. I have a theory now that the water I was mixing with the coolant was suspect...I was doing 50/50 concentrated and tap water. The tap water where I used to live is famous for corroding and eating hot water tanks in as little as two years.
              Once I get settled in from the move, I'm going to flush and fill again and add a ground strap from the core itself to the firewall.
              If that doesn't work, I dunno...the heater box is getting destroyed from being removed and replaced so much. Next time I'm going to need a box as well as a core.
                The shocks are getting worn out again in my Lincoln. Time for a new set methinks.
                Current suspension setup is fairly new stock front springs and stock front sway bar.
                Rear has used springs from a 1991 police Ford plus regular sway bar.
                Running P225/75/R15 tires all around with 32 psi as per police sedan specs.
                The Gabriel shocks that I put in back in 2007 weren't really very good from day one, I didn't like the ride as they tended to flutter after going over a bump.
                Anyone got suggestions as to what they think is the best shock to go with for my setup? I live in a place where the roads aren't the best, rutted pavement, frost heave and potholes are pretty normal.
                Might get a set for the OBS same time to save on shipping, the truck seems to be always in need of shocks. No matter what I get, it still bounces a lot, but with new shocks it bounces more softly than with old or cheap shocks. Hauling heavy loads isn't a huge concern, it's mainly my winter beater, occasional dump run truck.
                Thanks in advance.
                  For the front I have KYB 344081 on both of my cars with original springs and stock sway bar. I like them but they might not be soft enough for some people. They're listed for Police and Taxi under CV/MGM on Rockauto, but not listed at all for '88 TC.
                  For the rear, get some air shocks. I prefer the Gabriel HiJackers 49205 in The Ice Car over the Monroe Max-Air MA815 in The Scab. Mine are manual fill, but I wouldn't mind putting a stock system in with these shocks. With the air shocks you can run them at different air pressure depending on how you want them to ride. I tend to ride at the higher end of the pressure range, but running lower would soften them up quite a bit.
                    Distilled water is your friend. Its about a dollar a gallon at the store here. Any pharmacy or Walmart has it. My well water used to be absolutely horrid. It rotted the lead out of the original copper pipes. I wasn't about to put that in my engine. New well is not bad, but for how cheap distilled is, I'm not interested in risking it. I've even been known to buy 50/50 premix if I can get it for the same total price per gallon as making it myself. There is a surplus store in this area that sometimes has it for that price.
                      I have KYBs in the rear of my truck currently, don't really like them. They are mediocre. I've been reading good reviews of the Monroe Magnums.
                      I'm not terribly interested in setting my car up for air shocks, I don't haul enough weight really to justify that. Looking for a conventional shock that balances ride quality with handling. That's something that in my experience Gabriels don't do. I had a set of those in the truck and had to get rid of them quickly; it was all over the road, and bouncier than if the shocks were actually gone. The car handled them better, but still had that annoying little dance after going over a bump or washboard on pavement or gravel.
                      What I really want is some NOS non-gas pressurized hydraulic-only shocks, but with a big piston to dampen better than a regular old fashioned shock. But that's made of unobtainium I'm sure.
                      Might check out the police/taxi parts and see what's available, as the setup is more like a cop car than a Town Car.
                      My fuel sending unit is still working like a champ
                        That's the plan, to replace what's there with distilled water or 50/50 premixed. That's why I did the concentrate/water 50/50 mix on my own, due to the price of the 50/50 premix.
                        Now that I'm out of the sub-Arctic northern nether-region I can now get some stuff that's not stupidly expensive.
                          Police interceptor Monroe Magnums ordered for the Lincoln now from Rock Auto. I hope they work out!
                            Nice. Hopefully a good report on the new shocks, at least for your sake. I'd be curious to hear if they're too harsh/stiff or not.
                            I had a set of stock replacement Gabriel's on the front of my '89 years ago, and they were awful. I couldn't tell the difference between the completely dead originals and the brand new Gabriels. That car was parked not long after those shocks were installed, but I had no intention of reusing those shocks. However, the old Gabriel Hi-Jackers on the rear of that car and the new pair on The Ice Car I found to be great. You don't need to haul a ton-o weight to benefit from air shocks, just run lower pressure in them with less weight for a manual fill setup like mine, or adjust the sensor accordingly for the optional stock setup. I think the minimum pressure recommended for the Hi-Jakers is 25 PSI, I think I run around 150 PSI (haven't touched them in 3 years since I installed them), I think max is 225 (the max is much lower on the Monroes, like 125 PSI I think, I'm at 90-100 on those). Anyway, nothing wrong with not wanting to go the air route, it's just my preference and may not work for everyone.
                            Good to hear that sending unit is still working. I know Kevin discovered some of the late build '88 TCs in the JYs seem to have gotten the newer sending unit like '89 TCs got, luckily yours needed the older unit that we sent you.
                              Normally mixing your own is cheaper, but sometimes Ollie's (the discount store) has 50/50 that comes out to the same price per gallon, so I go the lazy route. I'm really not particular about who makes it or how, as long as its green and not mixed with river water I'm fine.
                                If you're looking for a "like factory" ride, you can always go for a Sachs shock. Those are pretty cushy shocks.
                                -Nick M.
                                Columbia, SC
