I have a strange problem after swapping outer sealed beams for H4 lamps with changeable bulbs homologated for Europe. Inner sealed beams are dimmed all the time when on low beams are turned on, see attached photo. It's similar behavior as described here. I have measured the voltage and low beams receive about 12.5V, high beams something below 2V in this state. After turning on the high beams, everything seems normal.
I have installed new headlight switch and also new multifunction switch (the one on the steering column) but the problem persists. Is it possible that this H4 conversion somehow instantly fries one of the new parts?
