Alrighty, bit of a 2-part question that has resulted from a bunch of tinkering, a lot of failed searches of this and the other 3-letter site, and general confusion. As I write this, it will become more than 2 parts, but that's how many I'm starting with...
Issue: idle RPM drops too low when car is put in gear. '91 MGM, stock.
Have base idle set around 700-900 depending on the accuracy of my cheap tach, followed procedure as found on article on SBFtech: http://sbftech.com/index.php/topic,1031.0.html
Idle was raised due to recommendation that it will assist with emissions test, as well as the fact that it was previously low enough to stall at various times.
There are other issues at hand and I have a beast of a thread on that other site, but right now I just need to clarify how the ECU responds to a drop in RPM.
If I am stopped, holding the brake pedal, and shift from park or neutral into reverse or OD/D/1, the RPM drops as much as 400RPM.
Assuming the IAC valve is functional: is the computer going to attempt to raise the RPM via the IAC?
I guess the question is, if base idle is set at some amount, and the throttle position sensor indicates the throttle is not open at all from its base position, if the RPM drops below that set amount, will the ECU compensate?
Some answers I've found suggest that the RPM drop is normal and ECU should not compensate. That doesn't make sense though, what is the purpose of having the IAC at all or even having a "base RPM" if the ECU will not continuously attempt to idle at that RPM?
My expectation is that the RPM will drop but quickly be compensated by the ECU opening the IAC as the RPM reported by the pickup is too low.
If someone(s) knowledgeable about the way this system is designed to operate can chime in that'd be fantastic, please. Brief reading about Chevies suggests my expectation is correct, but I'm having difficulty confirming for sure that Ford did the same.
