Does the regular odometer work? If it does, you could always just make a note of the mileage when you start and deduct that from the mileage when you stop...
EFI wows, about to scrap it!
Originally posted by DerekTheGreat View PostI don't think Ashley's Mark VII is right either. But it also does that thing where it flashes "0 DTE" when we flip the key on or start it so I think that's what is confusing it.
they tend to do that on the Mark VII. Might be the tripminder needs a rebuild too. Digidash doesn't have the antislosh module to throw into the mix, but thats another thing that causes that issue on analog dash cars. The DTE thing is way off base on those anyway. Full tank says like 430 miles, reality is about 350 at best, and it takes approximately 10 miles driving to go from 50 miles to empty to 0 mile to empty on the trippy thing. The average fuel economy number tends to be accurate though.86 Lincoln Town Car (Galactica).
Originally posted by 86VickyLX View PostThat has a fuel level sending unit or ground issue. That's what ails the tripminder.Originally posted by gadget73 View Postthey tend to do that on the Mark VII. Might be the tripminder needs a rebuild too. Digidash doesn't have the antislosh module to throw into the mix, but thats another thing that causes that issue on analog dash cars. The DTE thing is way off base on those anyway. Full tank says like 430 miles, reality is about 350 at best, and it takes approximately 10 miles driving to go from 50 miles to empty to 0 mile to empty on the trippy thing. The average fuel economy number tends to be accurate though.1985 LTD Crown Victoria - SOLD
Originally posted by DerekTheGreat View PostDoes the regular odometer work? If it does, you could always just make a note of the mileage when you start and deduct that from the mileage when you stop...
I was going to replace fuel filter since it is un-known when if ever it has been replaced. I got a Fram but it does not come with new O-rings which I have seen recommended to replace at the same time. Is it just a standard 5/8" O-ring from Autozone or is there a specific part number ? Was also going to start on suspension this weekend.
The o-rings are usually not an issue unless you get a filter with a burr on it that slices the o-rings. The ones on the Mad Marquis (88 MGM) are still original I think. Work fine as of when I sold it.
x2 on that, I've done fuel filters twice each on my 84 and 91, didn't replace O-rings and have no leaks. It's the sort of thing that might be smart to have on hand, though.
They're just O rings, but they have to be something fuel compatible. Pretty sure its the same O ring the fuel injectors use though. I've also never replaced mine, they're original from 1986 as far as I know.86 Lincoln Town Car (Galactica).
Originally posted by DerekTheGreat View PostGadget, by rebuild what does that mean? Like, can I get parts over the counter such as caps and what not?86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postyeah, new caps from Mouser, and swap the board off with alcohol to mop up any shite they may have leaked out. Not an absolute guarantee to fix it but it usually helps. Also helps with general braindead type problems. At one point mine was flashing between functions, time was running backwards, and it was randomly beeping and going generally batshit crazy. Fun to look at but really annoying to deal with while driving. The digital dash cars have a different fuel sender, I don't believe its the goofy dual resistance thing that the analog cars got.1985 LTD Crown Victoria - SOLD
I may have a cap list out in the shop for the tripminder. I'll check after dinner. Definitely do not have one for the digital dash.
Analog dash is apparently very different than the digital. As far as I know nobody has done a swap between them but I've never looked deep into it. I didn't want to deal with it so I bought an LSC that has proper gauges.86 Lincoln Town Car (Galactica).
Right, I'd rather do an LSC myself. This car just sort of happened upon us lol. Since it was the right vintage (90-92) and had all the parts needed to replace the bent ones (minus a bumper, some trim and a fender) and I couldn't find anything wrong with it mechanically it was just too good to harvest. Was supposed to be an HO donor for my TC. Then Ashley liked it and so I gifted it to her...
Any luck on that cap list? Guess I could be the guinea pig for the LSC cluster swap. As long as the fuel gauge kinda works I won't mind it but would certainly love to have an actual temp gage and a tach, not to mention a speedo that goes over 85.1985 LTD Crown Victoria - SOLD
Originally posted by DerekTheGreat View PostRight, I'd rather do an LSC myself. This car just sort of happened upon us lol. Since it was the right vintage (90-92) and had all the parts needed to replace the bent ones (minus a bumper, some trim and a fender) and I couldn't find anything wrong with it mechanically it was just too good to harvest. Was supposed to be an HO donor for my TC. Then Ashley liked it and so I gifted it to her...
