As first mentioned in WAYWO '26, I've acquired an aero! Apologies for the long first post, there've been a bunch of things to talk about with this one, but I held off on posting until it was clear I'd be keeping the car.
I have been keeping my eyes open for most of the year to try to spot an "easy button" option to have a winter beater this year without needing to finish the 89 Ranger project. I still intend to build that vehicle, but it became clear this wasn't going to be the year for it, so some other vehicle that would offer me better comfort and safety in the meantime vs the outgoing 85 Ranger would be a good thing. So, when a pretty clean looking 1994 Crown Vic turned up for 1500 Canadian, that seemed like a no-brainer.
203k km. Previous rust repairs to the frame (below AC drain) and one of the dog legs. Otherwise, not terrible.
History to-date:
I glued on the rear view mirror, and then I glued it on a second time after it fell off. Seems like the real key to success here is wire-wheeling the metal button to rough it up.
And then, of course, the windshield wiper misery.
https://www.grandmarq.net/vb/forum/t...cycles-94-ford
In addition to all of that, I also replaced the ball joints (one lower and both uppers) and tie rods (inner ends, outer ends, and sleeves). As a result, an alignment is required. It drives really well as it sits currently but the steering wheel is almost 90-degrees off. I will probably take a shot at improving this before a shop sees it because I don't want them to conclude they need to separate any joints and then charge more than a regular alignment to have done so.
There was a minor exhaust "puff puff" type of sound from a beginning-to-be-blown-out gasket on the right flange between the cat and Y-pipe. I broke all 4 bolts off, got it apart, cleaned it up nicely, and put it back together with new gaskets plus a healthy dose of exhaust sealant since the flanges weren't really flat and left visible gaps against the gaskets. Seems to have worked well enough. Hardware used was some crazy 12.9 M10 black oxide stuff I had hanging around...I drilled the holes out slightly larger for this to fit. Probably would have used stainless if I were buying it specifically for this job, but I had that stuff already.
Initially I had figured this would be an easy pass on the safety, but as you can see I did have to poke around with a bunch of stuff. I picked up the car on June 12 and finally got it in for its safety on August 17. My efforts were sufficient and the car passed. One of the tires is considerably lower tread than the others so I swapped on the wheels and tires from the wagon for the inspection, but I will be returning the previous tires to this car. As winter approaches, the winter tires on the 85 Ranger will get swapped on. They're on Panther 15" wheels so the hub bore size isn't an issue, and although the tires are fairly old now they look good and their tread is great. Hankooks seem to age well.
