Yeah, I am going to do that, I was just pissed lol
My 79 Marquis
So looking at the proportioning valve, its in bad shape and the fittings for the front brakes look like they will round out much like the other end....on a postive note looks like the rear brake lines have been done, or at least they are in much better condition. Google searchs came up kinda short on a new one....would this work?:
https://www.speedwaymotors.com/Speed...es,296892.html
1979 Marquis creamy goodness
Well, from bad, to worse, to worse.
I was able to take my wheel shroud off with very limited damage. I had full access to the proportioning valve. I was gentle, I PB Rrrrd to the Nth degree, I waited, I applied heat...., There is no way the lines are coming out of that valve, in fact, a brake line broke with the fuel line nut still in the valve. Needless to say I am out of four letter words for the month.
Can I cut out all the lines in good spots, so I can splice new ones in? Still not sure on a source for a proportioning valve. We do this for fun.....right?Last edited by Grand1; 06-03-2021, 09:19 PM.
Will do, he seems to have everything.... and your right might as well replace everything at this stage. Nothing beats tbe structural integrity of a complete line.
Originally posted by Mainemantom View PostI would not splice brake lines. In some States, that is not legal.
Well the proportional valve is definely toast. Was able to get the fuel nut off the broken line and plug it for the time being. It has a decent leak from another fitting now. Wagon man doesnt have any in stock right now, so I will be learning shortly if the Speedway valve will work. Since all the lines are gonna be redone, might as well and replace the master cylinder.....which leaves the brake booster as literally the last part not be replaced. The positive through all of this is that it has been baptism by fire about brakes, learned alot.
I always change the vacuum booster with the master cylinder.Parts have to have a lifetime warranty though. It saves doing the job twice. I can keep my eye out for a valve. If you have a part number on it, post it. I am sure you could get one via Car-part.com. out west. until you can get a new one.
Originally posted by slack View PostInteresting, I didn't know that. I think every vehicle I own at this point has patched brake lines thanks to road salt.
If you were to repair a brake line by flaring the end and using a union, there is no functional deficiency that I can imagine unless the line that was left in place was iffy...as for legality, I'm not so sure. It would pass a safety here and Ontario is really picky about stuff, regulating down to the number of drips of a particular diameter over a fixed amount of time that are allowable leaks for various fluids...(easily flammable ones such as power steering allow zero leak of any amount over any time, brake fluid of course also allows no leak over any amount of time).
Originally posted by Grand1 View Postmaster cylinderLast edited by kishy; 06-04-2021, 11:13 PM.
Yeah, thanks for the advice. I did purchase a booster and master might as well. I gave Summit a call and this universal valve will work....we shall see.
https://www.summitracing.com/parts/w...QaApVXEALw_wcB
Damn kish, just saw your post.... I have a master cylinder by raybestos( mc39531 part number ) sitting in my garage and actually was looking at replacing it as they look damn similar .... but crossed reffed the part number and didnt see the 79 listed, I deep sixed the idea.
....and yes I exercised that demon valve with four letter wordsLast edited by Grand1; 06-05-2021, 12:05 AM.
Originally posted by Grand1 View PostDamn kish, just saw your post.... I have a master cylinder by raybestos( mc39531 part number ) sitting in my garage and actually was looking at replacing it as they look damn similar .... but crossed reffed the part number and didnt see the 79 listed, I deep sixed the idea.
For reference if it comes up again, the master I used was an Autospecialty M81052, which is no longer sold.
If you look up a '91 Grand Marquis, you will find options for "police" or "HD" and also for not police or HD. You also find options for including a reservoir or not; for a retrofit like this, you need the reservoir as you have no existing one to swap over.
Some of them have a total of two outlets, some of them have a total of three outlets. There is not much consistency, some brands the police one is 2 ports, some brands the non-police one is 2 ports. If you get the 2 port one, you have to use an external splitter (nothing fancy, just turns one line into two) for the front brakes. If you get the 3 port one, you run both front brakes directly to the master. The rear will require a "proportioning" or "residual pressure" valve (depends who you ask as to what it's called) which threads in directly; I got mine from a junkyard as the new ones didn't come with it.
You also need to junkyard (or otherwise) source the low fluid level sensor which clips into the master and make a minor wiring connection to attach that sensor to the wiring that used to go to the switch on the valve. Not a big deal really.
These masters use metric threads for the flare nuts and bubble flares. On the late boxes that actually came with these things, it's a little piece of trivia...the other ends of the brake lines use double flares and SAE fittings, but the master cylinder end is all metric. Of course, 3/8 and M10 are close enough that someone not paying attention can put a 3/8 flare nut into the M10 hole, and if you crank it down tight enough, the double flare will seal by digging into the bubble flare seat, so it ends up working even though it shouldn't. In my relatively earlier days of wrenching I did exactly this thing to my 91.Last edited by kishy; 06-05-2021, 12:44 AM.
Originally posted by Grand1 View PostWell the proportional valve is definely toast. Was able to get the fuel nut off the broken line and plug it for the time being. It has a decent leak from another fitting now. Wagon man doesnt have any in stock right now, so I will be learning shortly if the Speedway valve will work. Since all the lines are gonna be redone, might as well and replace the master cylinder.....which leaves the brake booster as literally the last part not be replaced. The positive through all of this is that it has been baptism by fire about brakes, learned alot.
I'm late to the party here but one of the methods I use to remove brake lines and their fitting is to cut the line right at the fitting and then use a six point socket on it. This is my go-to method for any line I intend on replacing. I might try a line wrench, but if there's even a wiff of rust & decades, round-off is nearly guaranteed.1985 LTD Crown Victoria - SOLD
