Your video was a real treat. "Gee, I hope I remember where everything goes" - wonder how many times I've said that!
Ian's Boxy Wagon
not to sound like a wet blanket here, but why the 92 as a donor? Its got the weakest of the 4.6 engines and the same undersized front brakes you have now. I'm not a 4.6 fan anyway but if I were going to all the effort to jam one in, it would be a late one that actually makes more power than a stock HO does.86 Lincoln Town Car (Galactica).
It was the cheapest Aero in my area by quite a bit.
Plus it's low mileage (106K miles) and a rust free Arizona car.
Besides, having the later chassis with its motor and trans mounts and electronics sets the foundation for a better 4.6 or 5.4 down the road.
Same chassis. The motor mounts just unbolt, putting a 302 in an aero is just 3 bolts on each side to swap the motor mounts. they go in the same holes. Could go the other way too if you wanted.
I realize my disdain for the modular isn't an overly popular opinion, so don't take it as me crapping on your project.86 Lincoln Town Car (Galactica).
Well it's been a bit since the last update so here is where I am.
Starting to strip out the parts I may need for the chassis swap. That includes the dash and all of the interior wiring all the way back to the inertia switch in the trunk.
I hope to swap the 92 dash into the 79 CS and that includes the steering column. I plan to delete the air bags for safety (I know-sounds weird but the air bags aren't designed for the heavier and slightly different wagon) but I need the electronics for the dash and speedo.
Interior strip in progress.
Front end coming apart.
Anybody in Southern Alberta need aero body parts?
Speaking anecdotally here, as I haven't done what you're doing:- You will run into issues fitting and attaching the dashboard. There was a firewall (and floor pan) re-design for model year '90, and the items which fit prior to that year do not fit after that year without some tinkering. The HVAC plenum assembly is different, but I'm not sure how much and in what ways. User Mr Bean did a lot of related work in the course of getting the Mod Box to its current state (relatively recently so skim backwards from the end of the thread) in this thread: http://www.grandmarq.net/vb/forum/te...9497-New-ride=
- I am fairly confident that the air bag used in the steering wheel of a '92 is the same one used in a 90-91, which was indeed engineered for a wagon, and I am also fairly sure that your reasoning for deleting the airbag is maybe not sound. There are other very legitimate reasons to delete the airbag, however, such as it simply being old. I would consider it effectively neutered by simply unplugging it.
- The wagon and sedan frames are not the same over- and aft of the rear axle. The work to chop and mate pieces of each frame has been done by user pantera77 and you can see photos of that process in this thread: http://www.grandmarq.net/vb/forum/te...ony-park-build
- You can probably make some decent cash selling the fenders to someone in Ontario, as they're so rare that people will pay the value of an entire car for them if they're rust-free and nice.
Lots of good info there!
I knew the rear portion of the frame was going to need work and it's great to have that thread with pictures to reference.
I plan on just unplugging the airbag in the steering wheel and deleting the passenger side.
As far as the dashboard I figured on re-working some stuff and I don't think the dash and the a-pillars will match up. The Mod Box thread has inspired me and I have read and re-read it.
Shipping fenders? Isn't the shipping going to kill the wallet? If there is any interest I can post up pics once they come off.
Considering your location, you could probably sell the fenders locally and even if you shipped within reasonable areas (Canada), the people that would buy them will pay for the shipping as well.
Do you think a 4.6 would fit in a box? Evaporator box and wiper cowl -thing come to mind.Originally posted by gadget73 View PostCould go the other way too if you wanted.
I'm just curious knowing the possible fate of my 302...
Yes. See ModBox.Originally posted by Arquemann View Post
http://www.grandmarq.net/vb/forum/te...-grand-marquis
I'm waiting on a 7.3 Godzilla swap.86 Lincoln Town Car (Galactica).
- Likes 1
Swapped to an aero evap box and no wipers? I guess that's a no from me then... For now.Originally posted by sly View Post
A Godzilla swap seems more space friendly, even though the engine is tall, it's still more compact than a 4.6. Just need a low profile intake and then party.
Obviously LS swaps have been done. (On a long enough timeline, everything gets an LS it seems.)
351w swap is pure bolt on.
while I appreciate the LS, if its not in a Chevy or at least a GM product it doesn't belong there.86 Lincoln Town Car (Galactica).
- Likes 1
