Hey all,
I've tracked down a pristine, zero-slop used shift tube and lever to put in my 1991. As most of you will know this is more similar to an aero shifter than a box, due to the 90-91 redesign of oh-so-many little bits of the car.
I picked up a set of new bushings to go with it (Dorman 905107, O'Reilly seems to keep these as a regular stock item, other places not so regular), and am wondering what I should do for lubrication with this thing. I'll be cleaning it up, obviously, but I'm wondering what type of grease should be used. My thinking is to try to stuff the inside of the tube with grease as well as grease the bushings.
I have these options at my disposal. I'm leaning towards the wheel bearing stuff, or even the silicone dielectric grease because they're sticky and more likely to stay in place. Thoughts?
