The Townie has stayed faithful to me and continued to - knock on wood - run great. Fuel economy is looking a bit bleak but that roughly coincided with the drop in temperature so I don't really suspect much is wrong there. If I do the math and it's <10MPG I'll revisit that though.
A new problem has surfaced and so far also coincides with temperature. The engine will crank, sputter like it it's trying to start (so has air fuel and spark, just not in a mixture that it likes), but not actually fire up and continue running when the key is released. In order to start it in these cases, I've had to crack the throttle open to perhaps double cold idle while cranking and it starts without issue then. The same applies to holding it WOT and immediately releasing as soon as it starts, starts no problem.
It has happened 3 times: yesterday morning, this morning, and today after work. -11, -14, -9 Fahrenheit respectively, which are roughly the lowest temps this car has yet experienced with me.
Any thoughts on what's going on here?
FYI my starting procedure is:
Any thoughts? Is this typical of the CFI cars?
This car came to me with a remote start system installed, but I opted to remove it as I didn't have a remote for it. I'm having a hard time seeing how it could possibly work since there doesn't seem to be any way to set the fast idle cam when leaving the car...input there is also appreciated since I might choose to install one again.
FYI - not related to starting I'm pretty sure: my exhaust heat riser flapper valve thing is disconnected and fully open. The vacuum system to pull hot air into the intake from the exhaust manifold is capped off due to leaks. I realize these are probably causing it to take longer to warm up and probably part of my fuel economy issue since more of my (very short) commute is spent <130 degrees. On these cold days it's not even hitting 180 by the time I'm at work.
- punch the accelerator once to set fast idle
- turn to run, let the fuel pump prime (at least halfway through the prime, I don't just go straight to start)
- crank engine, normally starts no problem. Crank time will increase inversely proportionate to how short I let the fuel pump prime go for.
- if it did not start, repeat with throttle cracked open as described above, starts and runs
