Any time something that might kill you or someone else if it quits is in doubt its a smart idea to have it towed before an accident happens.
Master Cylinder For Dummies.............dat B me.
Originally posted by gadget73 View PostAny time something that might kill you or someone else if it quits is in doubt its a smart idea to have it towed before an accident happens.What I Own: 1993 Mercury Grand Marquis GS
When the master cylinder went on my 90 mgm, the pedal had a lot of travel before the brakes engaged but did work fine. I ended up getting a close out deal on rockauto. It was a remanufactured master that had been sitting for some time. I was a little leery of using it but it’s been fine for about a year now. I think I got it for like 10 bucks.
The clutch master cylinder in my K1500 is doing strange things similar to this. If I simply rest my foot on the clutch, it'll go to the floor with zero clutch disengagement. But if I quickly jab it to the floor, disengagement. Kind of fun to dink with, for now.1985 LTD Crown Victoria - SOLD
problem with that is you may find one day it decides to just nope out on you. Not quite such a big deal with a clutch, can just jam it into neutral and then just rev match it to get home.86 Lincoln Town Car (Galactica).
Oh yeah, been there and done this. It's actually been acting up for months, but has gotten to this point. Parts store this week to order new master and slave cylinder for it. Surprised I got ~5 years out of this set.1985 LTD Crown Victoria - SOLD
Yep, I'm definitely doing that this time around. Also going to vacuum bleed the system. I did this job about five years ago and did none of that, which required me to jack the ass of the truck up far into the sky to be able to get all the air out of the clutch master cylinder.1985 LTD Crown Victoria - SOLD
Originally posted by DerekTheGreat View PostYep, I'm definitely doing that this time around. Also going to vacuum bleed the system. I did this job about five years ago and did none of that, which required me to jack the ass of the truck up far into the sky to be able to get all the air out of the clutch master cylinder.
For brakes, this level of insanity doesn't often come up, but bench bleeding the master (or at the very least, bleeding it on the vehicle but just with little tubes feeding back into itself) can help with some obnoxiously difficult trapped air and is well worth doing.
This is for my GM truck, but I do wish that Ford was a stick. I ordered parts yesterday and they did have the complete assembly available. However, it was over $100 more than just the slave cylinder and clutch master cylinder so I decided to torture myself again.1985 LTD Crown Victoria - SOLD
Originally posted by Mainemantom View PostI know most repair places don't do this but I always bench bleed the replacement master cylinder before installation.
can do it easy if you pressure bleed them. Just shove fluid through the lines until it comes out the end. Master will mostly fill and mostly work, but there will usually be enough air stuck in it to feel funky. Vac bleed works too, but I've never had a lot of luck with that. Usually it sucks air around the bleeder so you can't actually tell when all the air is out of the system.
I've always just done the very manual process of pumping the thing with the little lines looped over to the reservoir until its bled, then pumping until the whole system is burped out. Takes 2 people but its pretty much guaranteed to work.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Post...Vac bleed works too, but I've never had a lot of luck with that. Usually it sucks air around the bleeder so you can't actually tell when all the air is out of the system...1985 LTD Crown Victoria - SOLD
