This has been kinda-sorta addressed in the past, but not really in a whole lot of detail...or, in photos that have ceased to exist in threads.
My 1983 Grand Marquis has probably the completely basest of base model stereos:
![Click image for larger version
I have acquired the faceplate trim of a newer box to properly fit a 1-DIN stereo once mounted:
The problem I'm running into is that there is no real way to mount a radio in this hole that doesn't have appropriate brackets. I picked up a set of the factory Ford ones that adapt a Ford 1-DIN radio to mount in the same location with the same spaced screw holes, but there is no real way to mount them to my new stereo...
Kits such as this...
...are not "supposed" to be used for "mounting" the radio, e.g. the weight of the unit is supposed to be supported elsewhere.
What solutions are people using to actually support the weight of the head unit? If there was a straightforward way to reuse the giant metal hook thing on the bottom of the stock radio it would be awesome, but there doesn't seem to be a way to do that.
Any input is appreciated...
Also, as an aside, this system is common ground, but the grounds for the speakers are separate up to the radio itself. The connector on the radio is what bridges them together.
